Author Topic: JavaScript: Writing to File?  (Read 23982 times)
Adam P
« on: January 15, 2015, 08:54:54 am »
Is there any way to write to a file using JavaScript / JScript from EA?
Re: JavaScript: Writing to File?
« Reply #1 on: January 15, 2015, 09:35:59 am »
Both JScript and JavaScript in EA can create an ActiveX object. For Javascript you'll find an example under the simulation section of the help.
See http://msdn.microsoft.com/en-us/library/aa242706%28v=vs.60%29.aspx for the object to create and how to use it.
Adam P
« Reply #2 on: January 15, 2015, 01:06:42 pm »
Thanks, that produces the error "CreateObject is not defined" (and a similar error with ActiveXObject). Is there some package I have to import?
« Reply #3 on: January 15, 2015, 06:45:48 pm »
For JScript you have to use "new ActiveXObject" similar to this:
var openFileDialog = new ActiveXObject("MSComDlg.CommonDialog");
For JavaScript use "new COMObject" similar to this:
var obj = new COMObject("WMPlayer.OCX");
See also http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1256123373/1#1
Adam P
« Reply #4 on: January 16, 2015, 10:40:59 am »
Thanks again, looks like I'm getting closer. I now get the error "Failed to create object from CLSID". I tried both "Scripting.FileSystemObject" and ""{0D43FE01-F093-11CF-8940-00A0C9054228}" (which is the CLSID for Scripting.FileSystemObject). I also confirmed that the CLSID is in the registry and associated with Scripting.FileSystemObject and scrrun.dll, and that scrrun.dll is in the Windows\System32 folder.
Can someone else drop these lines into a new JavaScript file and see if it works for them?
      var fs = new COMObject ("Scripting.FileSystemObject")
      var fs = new COMObject ("{0D43FE01-F093-11CF-8940-00A0C9054228}")
Any other suggestions from the pros on ways to write to a file from JavaScript or get COM to work?
Thanks again.
« Reply #5 on: January 16, 2015, 11:06:03 am »
It's possible that it's blocked by Windows (because it's a potential security hole in IE) can't remember the details.
« Reply #6 on: January 16, 2015, 06:29:01 pm »
I seem to have the same problem in JavaScript, but not in Jscript.
This code works in Jscript
function main()
      var fso = new ActiveXObject("Scripting.FileSystemObject");
      a = fso.CreateTextFile("c:\\temp\\testfile.txt", true);
      a.WriteLine("This is a test.");
      a.Close();
main();
Adam P
« Reply #7 on: January 16, 2015, 06:47:51 pm »
After installing the Microsoft Script Debugger that works.
Thanks again, I really appreciate the help.
