Author Topic: Link use case  (Read 9305 times)
dvarzoni
Link use case
« on: November 22, 2004, 04:03:37 am »
I have 2 diagrams in one same project. How I make one link of one for
the image of another one? Therefore I perceived that when selecting in
one it uses marries, is shown the description, I I would like the o to
clicar, to show the drawing of another one uses marries. :)
Bruno.Cossi
Re: Link use case
« Reply #1 on: November 22, 2004, 09:48:23 am »
I am not quite clear on what is it that you need, but it seems like you want to create a "hyperlink" one a diagram, leading to another one.
You can open a diagram, then drag the other diagram from Project View onto the open diagram and drop it there. That will create a hyperlink (or a diagram frame, dependent on your choice).
I notice the word "clicar" and assume you are a Spanish-speaker, if you wish drop me a line in Spanish and I will walk you through it.
Hope this helps.
Bruno
dvarzoni
Re: Link use case
« Reply #2 on: November 22, 2004, 10:10:39 am »
I´m a portuguese-speaker, sorry write a wrong word.
I want to do a hiperlink beetwen diagrams, but  when i select an use case, i want to see a drawing to another use case.
Ex: I want an use case 'First', when i select this use case i want to see the picture with another nivel this use case.
In the EA generate 'UseCase link from usecase [SI].Autorizacao ', but i want to see the drawingwith the others use cases.
Do uou understand me?
Re: Link use case
« Reply #3 on: November 22, 2004, 11:21:28 am »
I guess Bruno will also understand portugese  ;D
Bruno.Cossi
Re: Link use case
« Reply #4 on: November 22, 2004, 02:25:55 pm »
He might :-)
Bruno.Cossi
Re: Link use case
« Reply #5 on: November 22, 2004, 02:27:08 pm »
try Portuguese, you can send it via e-mail so we don't annoy everyone on the forum. I am not fully clear on what you want to do, but I am quite sure EA support that. (Now was not that a nice sales pitch?)
Bruno
