Author Topic: Version 3.50 - Build 582 released  (Read 24693 times)
sparks
« on: November 25, 2002, 04:24:29 am »
Changes in Build 582
- Changes to XMI 1.0 importer/exporter
- Modified SQL Server date formatting for languages other than english
- Modified Relationship Matrix: added TestCase as an option - differentiated UseCase and TestCase
- Modified Relationship Matrix: added classifier name for instance variables
- Modified way collection classes are used on association roles with multiplicity > 1
     1. Project level settings for each language in View/Options for each language
     2. Class level setting on Class Detail page of class property dialog
     3. Association level setting on Role page of link dialog
     For level one and two, you can set a default collection class, a class to use
     when the multiplicity is ordered and one to use when it is qualified.
     When generating code, the precedence is 3,2,1
     Search the help file for "Collection Classes" for more information
- Modified the docked property 'requirements and constraints' property page - now allows adding, modifying and deleting of requirements and constraints directly from the context menu
Modified HTML generator to produce hyperlinks to cross referenced model elements
Added 'Is Linked From' section in Docked Property dialog 'Hierarchy' view
- Added option to diagram dialog to suppress attribute compartment on a per diagram basis
- Added option to diagram dialog to suppress operation compartment on a per diagram basis
- Added option to diagram dialog to suppress stereotype name on attributes and operations on a per diagram basis
- Added global option to View/Options/Diagram to suppress constraints on Association links
