Author Topic: compare xmi to package form automation script  (Read 3613 times)
Wade Brooks
« on: January 30, 2015, 08:08:37 am »
can the compare xmi to package be run via automation?  I need to be able to check if XMI file matches whats in the model for several hundred XMI files.     I am using version 11 of EA.     If the automation interface does not support this, what is the best way to work around it?
Re: compare xmi to package form automation script
« Reply #1 on: January 30, 2015, 09:26:32 am »
There are compare functions (search for Baseline) in the Project Interface.
Worst case is that you'll need to import the XMI as a baseline before doing the comparison.
