Author Topic: RTF-Report - Custom SQL - Hyperlink in Notes-field  (Read 8492 times)
Jonathan Lubach
« on: January 20, 2015, 08:30:36 pm »
for excluding reasons I have added a Custom SQL template fragment to my overall template. In this fragment I use the "Custom" section with corresponding to the SQL query.
In the custom section I use a field "CustomNotes" receiving the values from the query "SELECT notes from t_object where..."
I have the following problem using this technique:
If the notes contain a hyperlink to another element, in the database this looks like this:
This is a note with <a href="http://$element://{51E2DB11-6109-4ca7-94AA-
DA0345CE39C2}"><font color="#0000ff"><u>hyperlink</u></font></a> to another element.
Using the notes in a normal "Pkg" or "Element" section will format this in a correction way:
This is a note with hyperlink to another element.
Using the "Custom" section does only print the text right from the database field:
Is there any way to get around this misformatting?
Thanks!
Jonathan
« Last Edit: January 20, 2015, 08:33:51 pm by syboowa »
Enterprise Architect Corporate Edition v12.1
Windows 7 64bit
OpenIT Solutions
Re: RTF-Report - Custom SQL - Hyperlink in Notes-f
« Reply #1 on: January 20, 2015, 11:23:13 pm »
In custom SQL fragment you need to name the column 'note' or 'notes' - sorry can't remember which of the top of my head....
Jon.
Jonathan Lubach
« Reply #2 on: January 21, 2015, 05:10:09 am »
Hi Jon,
thanks for your reply. I tried this in my template but it does not work.
When using "t_package.Notes as Notes" the behaviour is equal to that described in my first post.
When using "t_package.Notes as Note" I get an error message from the JET engine saying there are reserved key words in the query.
I don't know if I made clear enaugh: I'm using the option "Custom Query" option in the "Document options" of the template creator.
When using this I have to use the "Custom"-section from the section selector.
In the custom section I cannot use the standard fields provided, e.g. let's say the "Pkg" or "Element".
I have to define my own fields and use them. E.g.:
select t_package.Name as CustomPackageName, t_package.Notes as CustomPackageNote, t_package.package_id from t_package
where package_id = #PACKAGEID# and package_id in
(select package_id from t_object where package_id = #PACKAGEID#
and object_type = "requirement")
Thanks!
Jonathan
« Last Edit: January 21, 2015, 05:11:33 am by syboowa »
Windows 7 64bit
OpenIT Solutions
« Reply #3 on: January 28, 2015, 05:59:55 am »
You get an error with:
select t_package.Name as CustomPackageName, t_package.Notes as Note, t_package.package_id from t_package
Jonathan Lubach
« Reply #4 on: February 02, 2015, 06:58:24 pm »
I think your reply was a question?  :P
Yes, I get the following error from the JET-engine (I hope I found the correct translation, the message is displayed in german):
"Run-time error '3141': The SELECT statement includes a reserved word or an argument name that is misspelled or missing, or the punctuation is incorrect."
If I replace
t_package.Notes as Noteby
t_package.Notes as MyNoteit works.
Jonathan
Windows 7 64bit
OpenIT Solutions
« Reply #5 on: February 03, 2015, 01:40:50 am »
Does it work if you use ....
select t_package.Name as CustomPackageName, t_package.Notes as [Note], t_package.package_id from t_package
Jonathan Lubach
« Reply #6 on: February 03, 2015, 02:10:52 am »
Hi Jon,
just quickly executed this search in the model search and the result was:
The notes column is not visible :-/
At the moment I do not have the possibility to try this way in a template fragment...
I will come back if I tried it.
Thanks.
Jonathan
Windows 7 64bit
« Reply #7 on: February 03, 2015, 08:46:32 am »
There is a View Notes command in the toolbar for the Model Search. It gives you a choice of Hide Notes (which is default), Notes Preview, or Full Notes.
Jonathan Lubach
« Reply #8 on: February 03, 2015, 06:59:52 pm »
Hi KP,
thanks for the answer; I assume that is the difference between a custom-named column (e.g. "t_package.Notes AS MyCustomNotes") and the special "[Note]" column?
I will try that as soon as possible in my report fragment template.
Thanks!
Jonathan
Windows 7 64bit
Henrik Possung
« Reply #9 on: February 03, 2015, 07:30:22 pm »
I think I have found a workaround for this. I filter the elements I want with my SQL query  like this:
SELECT t_object.Name AS ElementName
FROM t_object
WHERE …
Then in the custom field I use the ElementName, but instead of a custom field for notes, I use the generic “Element.Notes” (cut from some other template) :
custom >
{ElementName}
{Element.Notes}
< custom
I’m not sure this solves you problem, but it seems to work fine in my case.
Henrik Possung
« Reply #10 on: February 03, 2015, 08:18:27 pm »
I just discovered that this is only valid if #OBJECTID# is not null, that is, if your model template are linking to a custom fragment from the element. In my case I can get the element notes, but not the package notes, doing like this.
Model Template:
package>
element>
{myCustomFragment}
<element
<package
myCustomFragment:
custom >
{ElementName}
{Element.Notes}
< custom
In your case, you will get the #PACKAGEID# and therefore can get the  Pkg.Notes
Model Template:
package>
{myCustomFragment}
<package
myCustomFragment:
custom >
{PackageName}
{Pkg.Notes}
< custom
