Author Topic: Adding a package with VB Script  (Read 6276 times)
Jayson
« on: March 09, 2015, 07:58:34 am »
Believe it or not, even after having done a LOT of script I have NEVER used scripting to add a new package.
However, I now have the need to and am failing miserably for some reason.
My script looks like this:
Set m_rootPackage = Repository.GetElementByGUID(rootPackageGUID)
Set m_targetPackage = m_targetPackage
Set package = m_targetPackage.Packages.AddNew(m_packageName,"")
package.Update()
package.Packages.Refresh()
Unfortunately when I call Set package = m_targ.... I get the following error:
Object doesn't support thisproperty or method:'Packages'
Any help gratefully received :-)
Re: Adding a package with VB Script
« Reply #1 on: March 09, 2015, 09:04:36 am »
does nothing. You likely want
Set m_targetPackage = m_rootPackage
to add the new package to the root. Else if you want to add to another exiting package use
Set m_targetPackage = Repository.GetElementByGUID(myotherGUID)
Then you can add via
« Reply #2 on: March 09, 2015, 06:18:42 pm »
Almost there. But you should get the package using
Set m_targetPackage = Repository.GetPackageByGuid(myotherGUID)
This will result in an EA.Package element, which has the .Packages attribute.
If you use GetElementByGUID you get an EA.Element object, which doesn't have .Packages.
« Reply #3 on: March 09, 2015, 08:25:58 pm »
That happens if you copy/paste without thinking :-[
