Author Topic: Looking for parent of parent  (Read 4241 times)
Gusztav
  • EA expert
    • Imprestige. Your issues in safe hands.
« on: March 09, 2015, 04:29:27 am »
Hi. I have a bunch of activities organized into a hierarchy. For each activity, an activity diagram is specified with partitions and sub-activities, so the hierarchy looks like this:
Activity 1
  + Partition 1
      Subactivity 1 by Partition 1
      Subactivity 2 by Partition 1
  + Partition 2
      Subactivity 1 by Partition 2
      Subactivity 2 by Partition 2
I'm trying to develop a SQL search finding subactivities for activities, that is, those items being second-level children, to keep it simple.
I thought the following would work, but it does not:
select
    subActivity.ea_guid as CLASSGUID,
    subActivity.Name as [Task],
    subActivity.Object_type as [Type]
from
        t_object as activity
        inner join t_object as partition
            on partition.parent_ID = activity.Object_ID
        inner join t_object as subActivity
            on subActivity.Parent_ID = partition.Parent_ID
where
    activity.Object_Type in ('Activity', 'Action')
    and
    activity.Name like '#WC#<Search Term>#WC#'
order by activity.Name, subActivity.Name
When running the query, I receive a DAO 3061 errors, saying "Too few parameters. Expected 2". Trying to run the query in a 3rd party tool on the EAP file yields in error "Parameter partition.parent_id has no default value".
I have also tried the following variant of the query:
select
from
      t_object as activity,
      t_object as partition,
where
      partition.Parent_ID = activity.Object_ID
      and
      subActivity.Parent_ID = partition.Object_ID
      and
      and
The results are the very same.
Could you, please, tell me what am I doing wrong? I know error 3061 usually refers to names what JET can not resolve, but I could not find such a typo in the code. And why lack of a default value would prevent me from checking the equivalence of such a field?
Gus
« Last Edit: March 09, 2015, 04:31:08 am by imprestige »
Re: Looking for parent of parent
« Reply #1 on: March 09, 2015, 06:47:29 am »
ParentID instead if Parent_ID will likely solve the issue.
« Reply #2 on: March 09, 2015, 06:24:35 pm »
A good idea to avoid these kind of issues is to use an external SQL editor to create your SQL queries.
I use a free "universal" tool called  AnySQL Maestro but there are many similar tools like that.
The "intellisense" feature of those type of editors usually helps to avoid typos.
« Reply #3 on: March 09, 2015, 08:28:10 pm »
EA has also some of that "intellisense" but it's not that smart. It only works after you write the table name and the dot, not for an alias.
