Author Topic: Quicklink Definition for Composition Direction  (Read 3415 times)
allist
« on: March 11, 2015, 05:15:23 am »
I am creating a quicklink document and one of the definitions is to include a composition with a direction from target to source, such as:
However, I can't reproduce this relationship in a quicklink document entry.
I have two different entries that get close but not what I am looking for
Class,ChiController,UseCase,ChiBusinessUseCase,,,,Composition,RefinedBy,directed,RefinedBy,,TRUE,,TRUE,TRUE,Analysis,0,,,,TRUE,0
Which produces:
Which has no arrows, no good.
If I specify "from" in the "New Link Direction" column, then the diamond in the composition link gets switched instead of adding an arrow.
The only arrow time I got the arrow was if I put "bidirectional", which isn't what I want either:
Is it possible to write a quicklink definition to get the result in the first image, or is that not possible?
Thank you!
Re: Quicklink Definition for Composition Direction
« Reply #1 on: March 11, 2015, 07:25:39 am »
QL is tricky, especially when doing such "strange" things. I guess you need to cross fingers that one of the smart Sparxians is reading this and has an idea. Good liuck.
