Author Topic: Diagram layout  (Read 6217 times)
Monsieur
Diagram layout
« on: March 26, 2015, 09:20:42 pm »
Hello sparxian,
Little nothing today, but couldn't find a solution:
[size=16]Can we manage diagram automaticaly in EA as you can do manually by defining the layout of a Driagram to Box or Digraph?[/size]
something like (THIS DOES NOT EXIST, i just dream about it)
          currentDiagram.Layout(Digraph)
           Repository.ReloadDiagram(currentDiagram.DiagramID)
would have been perfect :p
I saw about EA Matic, but it only manage lines no?
http://bellekens.com/2015/03/14/configure-your-own-default-line-styles-in-enterprise-architect-with-ea-matic/
I am sure there is a function but i can't find it.
Thank you
philchudley
Re: Diagram layout
« Reply #1 on: March 26, 2015, 10:03:24 pm »
Interesting
The closest I could find is the following
LayoutDiagramEx (
string DiagramGUID,
long LayoutStyle,
long Iterations,
long LayerSpacing,
long ColumnSpacing,
boolean SaveToDiagram
this method is defined in the Project class
This may partially address what you are looking for
Phil
Models are great!
philchudley
Re: Diagram layout
« Reply #2 on: March 26, 2015, 10:09:46 pm »
Follow up post, the method LayoutDiagramEx appears to use the Digraph style
Phil
Models are great!
Re: Diagram layout
« Reply #3 on: March 26, 2015, 11:04:44 pm »
In one of the other examples: Self-maintaining diagrams in Enterprise Architect with EA-Matic I use automatic layout of diagram using this code below:
'layout the auto diagram
function layoutAutoDiagram(diagramID, model)
    dim diagram
    set diagram = model.getDiagramByID(DiagramID)
    'if the diagram is an auto diagram then we do an automatic layout
    if Left(diagram.name,LEN("AUTO_")) = "AUTO_" then
        'auto layout diagram
        dim diagramGUIDXml
        'The project interface needs GUID's in XML format, so we need to convert first.
        diagramGUIDXml = Repository.GetProjectInterface().GUIDtoXML(diagram.wrappedDiagram.DiagramGUID)
        'Then call the layout operation
        Repository.GetProjectInterface().LayoutDiagramEx diagramGUIDXml, lsDiagramDefault, 4, 20 , 20, false
    end if
end function
Monsieur
Re: Diagram layout
« Reply #4 on: March 27, 2015, 07:18:55 pm »
Well, thank you both!
I must look deeper into that LayoutDiagramEx function (which seem to be the only solution (but it seem a bit harsh to apprehend).
@Geert Bellekens
I 'll give a try to your function Geert (by including it into a Library and calling it). I'll give you some feedback about it. Thanks for giving pieces of your code so kindly.
Sparxians are the best  ;D
Re: Diagram layout
« Reply #5 on: March 27, 2015, 07:25:30 pm »
To avoid confusion, we usually use the term "Sparxians" to denote employees of Sparx Systems.
Neither Phil nor myself are employed by Sparx Systems, although we both work for a Sparx Systems partner.
You can recognize actual Sparxians by the red color of their name (Simon, RoyC, KP,...)
Monsieur
Re: Diagram layout
« Reply #6 on: March 27, 2015, 07:38:45 pm »
Hum sorry for my vocabulary mistake, thanks for pointing that out!
[size=18]Sparx community*[/size] is the [size=18]BEST[/size][/b]
 ;)  ;)  ;D  ;)  :D
Monsieur
Re: Diagram layout
« Reply #7 on: March 27, 2015, 09:16:36 pm »
So many functions i dont know!!!!
Some feedback.
function layoutAutoDiagram(diagramID, model) //[color=#0000ff]model is Repository ?[/color]
   dim diagram
        dim diagramGUIDXml
        diagramGUIDXml = Repository.GetProjectInterface().GUIDtoXML(diagram.wrappedDiagram.DiagramGUID) [color=#0000ff]//wrappedDiagram? is that a real thing :p?[/color]
   end if
end function
A normal GUID is like {B303A097-298B-4e59-8261-225E63C3AC19}, what should look like an XML guid? <GUID>B303A097-298B-4e59-8261-225E63C3AC19</GUID>??
EDIT: Okay found out.
Here is my solution (in JS):
var currentDiagram as EA.Diagram;
currentDiagram = Repository.GetCurrentDiagram();
var diagramGUIDXml
diagramGUIDXml = Repository.GetProjectInterface().GUIDtoXML(currentDiagram.DiagramGUID)
Repository.GetProjectInterface().LayoutDiagramEx(diagramGUIDXml, lsDiagramDefault, 4, 20 , 20, false);
It does not work perfectly, but it's better and i don't know how to solve the problem... It's still not as good as Layout Box or Layout Digraph.......  :'( :'( :'( :'(
