Author Topic: Traceability Matrix document generation  (Read 6092 times)
user_368285
« on: April 09, 2015, 01:06:02 am »
Hi all,
I need to generate a traceability Matrix, or my requirements.
I have tree level of requirements:
1) Customer requirements
2) System requirements
3) Segments requirements
I have the "satisfy" relationship for requirements:
a) System satisfy Customer
b) Segments satisfy System
Relationship are 1 to n.
I want a Matrix with the following items:
[/td][/td]
Customer[td]System[td]Segments
and
[/td][/td]
Segments[td]System[td]Customer
I used template for document generation, but I don't know how indicate
"target element" of "target element"
Can anyone help me?
Thanks all.
Robert Sheridan
Re: Traceability Matrix document generation
« Reply #1 on: April 13, 2015, 11:48:02 pm »
I suspect you will have to do that via the Automation Interface from a macro enable spread sheet.
OpenIT Solutions
« Reply #2 on: April 16, 2015, 07:16:03 pm »
There will be a number of ways to achieve this. The simple way is to structure your model to work with the document generator. This means nesting your requirements as child elements:
Customer Requirement with Child System requirements with child segment requirements...this falls over when a system/segment requirement is shared. But in your template you would just include a <child elements> section...
Another way is to create a traceability diagram. Place your Customer Requirement on a diagram, then right mouse click and use the Insert Related feature... then just include the diagram in your report...
Hows your SQL ? You could create a template that includes your top level customer requirement then uses a diagram fragment with custom SQL to retrieve and display all related elements and there related elements etc...I use SQL Server so I achieve this by creating a view on the server that uses the SQL Server CTE capability, then include the view in a simple select statement within my fragment...
user_368285
« Reply #3 on: April 16, 2015, 11:38:50 pm »
I'm not able to think that a tool as Enterprise Architect oblige a buyer user to create a Macro with Excel to realize a simple operation as above descripted.
I think this operation is a common operation in requirement management, then for all buyer users of Enterprise architect.
