Author Topic: add Image to a EA Image Library via Script  (Read 4260 times)
HTB
« on: May 09, 2015, 02:59:14 am »
Is there any way to add image to the Library without using the Image Manager ??
I would like to add several images to Image Manager via script.
Does anyone have a code snippet solving this requirement?
Re: add Image to a EA Image Library via Script
« Reply #1 on: May 09, 2015, 03:14:17 am »
You can import them into the table t_image directly. The image is simply stored as blob. Just import an image manually and see what t_image contains. It should be easy to mimic that programmatically (I've done that more than once).
HTB
« Reply #2 on: May 09, 2015, 07:25:05 am »
Thanks  I will review.
