Author Topic: Launch EA Programmatically  (Read 4689 times)
Tehila1
« on: May 26, 2015, 05:51:57 pm »
I would like to open an EA session via Windows service (C#) and do some actions behind the scenes.
I use the Repository API, however, don't know how to initialize it correctly.
    EA.Repository repository = null;
    repository.OpenFile(@"C:\test.eap");
    repository.Exit();
The OpenFile() fails due to wrong initialization :"Object reference not set to an instance of an object".
Any help would be appreciated!
Re: Launch EA Programmatically
« Reply #1 on: May 26, 2015, 06:16:12 pm »
I think it would really be a good idea to follow a general programming course before trying something advances such as using the EA API.
You can a nullPointerException on OpenFile() because the object repository is null; which you defined the in the previous line.
You can't execute methods on null.
Tehila1
« Reply #2 on: May 26, 2015, 06:53:14 pm »
That's exactly why I asked how to initialize the repository!
Windows service wouldn't allow to use  EA.Repository repository = new EA.Repository(); since it has no interaction with UI (ActiveX component).
If you have answer to the initialization question, It would be great.
« Reply #4 on: May 26, 2015, 07:39:21 pm »
Use
EA.Repository repository = new EA.RepositoryClass();
« Last Edit: May 26, 2015, 07:39:43 pm by Geert.Bellekens »
