Author Topic: DAOerror Updating Constraint.Name=0 to another val  (Read 3752 times)
pisokol
« on: June 16, 2015, 11:57:06 pm »
In EAP I have the element with defined constraints. One of this constraints has constraint.name set to "0" (zero). In my addin (c#) I find this constraint and set constraint.name to another value ("A"). Next I try to update this constraint and I have the error
DAO.QueryDef [3075]
Syntax error (comma) in query expression ...
Finaly this update is working and this changes are stored in EAP.
My problem is, how can I catch this exception in my addin code, because this is error is shown in separate window and stoped whole proces.
EA.IDualElement el = Repository.GetElementByID(<Element.Element_ID>);
foreach (EA.IDualConstraint con in el.Constraints)
                        if (con.Name == "0")
                            con.Name = "A";
                            try
                                con.Update();
                            catch (Exception ex1)
                                MessageBox.Show("My Error" + Environment.NewLine +
                                    "Exception.Message" + Environment.NewLine +
                                    ex1.Message + Environment.NewLine +
                                    "Repository.GetLastError()" + Environment.NewLine +
                                    Repository.GetLastError() + Environment.NewLine +
Re: DAOerror Updating Constraint.Name=0 to another
« Reply #1 on: June 17, 2015, 02:03:15 am »
There is no way of suppressing this error. If you can reproduce this you should contact Sparx support as it indicates an error in the API.
pisokol
« Reply #2 on: June 17, 2015, 06:34:31 pm »
thx
