Author Topic: Crash of scripts  (Read 7135 times)
Monsieur
Crash of scripts
« on: June 23, 2015, 07:20:51 pm »
If i use twice the same script i got an error message:
or
Any idea? I am over using EA memory?
Re: Crash of scripts
« Reply #1 on: June 23, 2015, 08:35:25 pm »
It think the script engine somehow looses the connection to the database, possibly because of an error.
Try checking dberror.txt. If you are lucky there's an error in there that says a bit more.
Monsieur
« Reply #2 on: June 23, 2015, 10:19:14 pm »
Where can i find this little guy?
I didn't found it in C:\Program Files (x86)\Sparx Systems\EA....
« Reply #3 on: June 23, 2015, 10:24:55 pm »
%appdata%\Sparx Systems\EA
Monsieur
« Reply #4 on: June 23, 2015, 10:29:45 pm »
And this is supposed to help :p?
23/06/2015 11:21:10
DAO.Database [3014]
Can't open any more tables.
Context:
      SQL: select t1.Name, t1.ea_guid from t_object t1, t_object t2 where t1.ea_guid = t2.PDATA1 and  ( t2.Object_ID IN (1035) )
PS: thank you for this, i didn't know EA logged crash errors.
« Last Edit: June 23, 2015, 10:34:21 pm by damien.reche »
« Reply #5 on: June 23, 2015, 10:37:33 pm »
It's better then only "Can't open any more tables" isn't it?
It looks like you are hitting some of the limitations of MS Access.
see here: http://stackoverflow.com/questions/1807934/ms-access-cant-open-any-more-tables
It seems like it might help if you switch to Jet 4 iso 3.5 as apparently that can handle double the amount of table handles.
Monsieur
« Reply #6 on: June 23, 2015, 10:44:12 pm »
I am working on a local EAP.... I know eap are just access database.
-But how can i "upgrade" my eap to Jet 4?
-If i move to an SQL database will i have less errors?
M
« Reply #7 on: June 23, 2015, 11:50:32 pm »
M
- To upgrade I think you need to make a new model using the jet4 base .eap and then do a model transfer. (I'm not sure, I never needed that)
- I'm pretty sure you will have less errors of this kind of you move to a "real" database.
Monsieur
« Reply #8 on: June 23, 2015, 11:52:21 pm »
Don't know how to create a jet4 base .eap.
And did not find it in the help.
Can you give a me short list of "real"s database?
« Reply #9 on: June 24, 2015, 02:21:57 am »
It is somewhere on Sparx resource pages. There's a recent thread about it,. Likely the Search button will work here.
« Reply #10 on: June 24, 2015, 03:17:16 am »
Here's the EABase_Jet4.0
Here's a list of supported dbms's
Monsieur
« Reply #11 on: June 24, 2015, 06:04:00 pm »
Thanks for your help. Will look into that and post on forum if works.
 [smiley=tekst-toppie.gif]
