Author Topic: MDG: Quick Linker Menu - Elements Order  (Read 14670 times)
Re: MDG: Quick Linker Menu - Elements Order
« Reply #15 on: August 13, 2015, 09:51:33 am »
unfortunately no success till now ...
only way to achieve this was:
- instead of extending Archimate (or other) MDG, original UML element (i.e. Class) was extended first with own MDG stereotype (i.e. Service Consumer), and then added ALL the rest from the Archimate element (i.e. Business Actor)
- and then created QuickLink artifact, listing first own elements, and then, in sequence, adding the elements from the original Archimate ...
It works, but it is not easy maintainable, you have to reverse engineer everything from Archimate, and on the end you do not have Archimate any more, but only your MDG that is not Archimate extension, but only your own Archimate-like MDG ...
maybe in the future somebody finds the way how to do it in the simple way ...
rgrds,
ljk
Well ljk,
Thank you for confirming the above.
As it happens, we took the decision a while ago for other (related) reasons to create our own MDG and disengage from direct ArchiMate extension.  We reverse engineered the Sparx ArchiMate MDG and used it as  starting point for our specific one.
So far that's worked out well and your post seems to confirm our direction as the only viable one.
