Author Topic: C++ code generation  (Read 7177 times)
johnw@wessex
C++ code generation
« on: February 08, 2005, 06:26:40 am »
I'm trying out the demo of Enterprise Architect.
I created a class diagram containing a private static integer variable and then generated the C++ source code.
//  Class1.h
//  Implementation of the Class Class1
//  Created on:      08-Feb-2005 09:39:27
#if !defined(EA_CF70D464_4571_408e_AD98_FC90F6E31E1F__INCLUDED_)
#define EA_CF70D464_4571_408e_AD98_FC90F6E31E1F__INCLUDED_
class Class1
public:
Class1();
virtual ~Class1();
private:
static int some_variable;
#endif // !defined(EA_CF70D464_4571_408e_AD98_FC90F6E31E1F__INCLUDED_)
//  Class1.cpp
#include "Class1.h"
//**** THIS LINE IS MISSING FROM THE GENERATED SOURCE ****
int Class1::some_variable;
Class1::Class1(){
Class1::~Class1(){
Without the missing line the code is un-compileable!
Any thoughts?
Re: C++ code generation
« Reply #1 on: February 08, 2005, 06:45:05 am »
What do you mean by un-compilable? Why are you missing this line? Did you include this attribute in Class1 and it's not generated?
johnw@wessex
« Reply #2 on: February 08, 2005, 07:14:55 am »
A static variable declared in a class must be defined.
class MyClass
public:
   static int var;
int MyClass::var;
Correct
johnw@wessex
« Reply #3 on: February 09, 2005, 05:20:48 am »
Appearently it is a known issue and you must import this XML for it to work.
 <?xml version="1.0" encoding="windows-1252" ?>
- <RefData version="1.0" exporter="EA.25">
- <DataSet name="C++_Code_Template" table="t_template" filter="TemplateType='#TemplateType#' and TemplateName='#TemplateName#' and Style='#Style#'">
- <DataRow>
 <Column name="TemplateID" value="{A67D5899-C97E-4286-93AC-716A45218004}" />
 <Column name="TemplateType" value="C++_Code_Template" />
 <Column name="TemplateName" value="Attribute__StaticImpl" />
 <Column name="Template" value="%attType% %className%::%attName%%attInitial ? " = " value%;" />
 </DataRow>
- <DataRow>
 <Column name="TemplateID" value="{FD32BDFD-B7DD-4e8d-9D6B-E42831FF392C}" />
 <Column name="TemplateName" value="Class Body Impl" />
 <Column name="Template" value="$templateArgs=%list="ClassParameter" @separator=", "% %if $templateArgs != ""% $templateArgs="<" + $templateArgs + ">" $templ="template" + $templateArgs %endIf% $consPrefix=$templ + "\n" + %classQualName% + "::" %PI="\n\n\n"% %list="Attribute__StaticImpl" @separator="\n\n" attStatic=="T"% %if genOptGenConstructor == "T" and genOptGenConstructorInline != "T" and classHasConstructor != "T"% $consPrefix%className%(){\n\n} %endIf% %if genOptGenDestructor == "T" and genOptGenDestructorInline != "T" and classHasDestructor != "T"% $destructor=$consPrefix+"~"+%className%+"(){\n\n}" $destructor %endIf% %if genOptGenCopyConstructor == "T" and genOptGenCopyConstructorInline != "T" and classHasCopyConstructor != "T"% $consPrefix%className%(const %className%& the%className%){\n\n} %endIf% %list="OperationImpl" @separator="\n\n\n"% %list="InnerClassImpl" @separator=""%" />
 </DataRow>
 </DataSet>
 </RefData>
