Author Topic: Attribute ordering  (Read 6238 times)
Attribute ordering
« on: September 02, 2015, 10:12:01 am »
It's been a while since I manually worked with attributes (hence the number of bugs/issues I'm reporting).
Are we able to change the order of attributes manually?  I thought I have set up the appropriate options, but nothing I do allows me to change the ordering.
I know I can change the ordering in automation by using the API to alter the Pos column in the table, but I can't see how to affect it manualy.
Maybe it's "wood and trees", but I need help!
TIA,
VKN
Re: Attribute ordering
« Reply #1 on: September 02, 2015, 10:37:18 am »
Use CTRL + UP/DOWN arrows on the features dialog.
HarryPlotter
« Reply #2 on: September 02, 2015, 10:48:27 am »
Hi there Paolo.
In the 'Attributes' dialog, right-click on the attribute you want to re-order. Select 'move up/down' as appropriate.
We had to look for this recently, too! We have gone from EA9 to EA12 - there used to be little green arrow controls to re-order attributes. The arrows appear in the Project Browser, but they do not appear to be enabled when selecting 'attributes'. They are when selecting other package elements.
« Reply #3 on: September 02, 2015, 11:16:16 am »
Hi there Paolo.
Hi HP,
I have the same problem, I also just jumped from v9 to V12!
The arrows in the browser don't seem to work for me.  Do they for you?  They work for elements, but not for attributes.
« Reply #4 on: September 02, 2015, 11:19:38 am »
Thanks VKN,
It was "wood for trees".
I'd given up looking on the context menu since a lot of things that should be there often aren't - due to EAUI.
Still I should have checked...
