Author Topic: Convert To Instance via code  (Read 5465 times)
Gary Cleal
« on: September 02, 2015, 04:43:40 pm »
Does anyone know how to convert a class element to an Instance via code.. I am looking for a method equivalent to (diagram element right-click) "Advanced\Convert To Instance".
If there is no method(), are there a set of properties that could be set on an element to achieve the same result?
Re: Convert To Instance via code
« Reply #1 on: September 02, 2015, 04:53:33 pm »
No there isn't.
I wrote something a bit similar as part of a script a while ago.
This operation is used to convert BPMN activities used a "link" on a diagram to local BPMN activities that call this activity using the calledActivityRef tagged value.
Converting to instances is a bit the same thing. You just need to create a new object, set the classifierID to the classifier you are trying to replace, and replace the ElementID on the DiagramObject to the elementID of the new object.
Sets the object name to that of the classifier, and set the composite diagram for objects
function synchronizeObjectNames(diagramObject, diagram)
      dim element as EA.Element
      set element = Repository.GetElementByID(diagramObject.ElementID)
      synchronizeElement element
      'set default size for message objects
      if element.Type = "Object" AND element.Stereotype = "Message" then
            diagramObject.bottom = diagramObject.top - 25
            diagramObject.right = diagramObject.left + 40
            setFont diagramObject
            diagramObject.Update
      end if
      'check if it is local activity
      if element.Type = "Activity" and element.Stereotype = "Activity" and (element.PackageID <> diagram.packageID ) then
            'Make a new Activity for this activity
            dim callingActivity as EA.Element
            dim ownerElement as EA.Element
            dim ownerPackage as EA.Package
            if diagram.ParentID > 0 then
                  set ownerElement = Repository.GetElementByID(diagram.ParentID)
                  set callingActivity = ownerElement.Elements.AddNew("","BPMN2.0::Activity")
            else
                  set ownerPackage = Repository.GetPackageByID(diagram.PackageID)
                  set callingActivity = ownerPackage.Elements.AddNew("","BPMN2.0::Activity")
            end if
            'check if callingActivity was created
            if not callingActivity is Nothing then
                  makeCallingActivity callingActivity, element
                  dim updateDiagramObjectSQL
                  'set the element of the diagramObject to the new action
                  updateDiagramObjectSQL = "update t_diagramobjects set object_id = "& callingActivity.ElementID &" where Diagram_ID = " & diagramObject.DiagramID & " and Object_ID = " & element.ElementID
                  Repository.Execute updateDiagramObjectSQL
                  'synchronize
                  synchronizeElement callingActivity
                  Repository.AdviseElementChange(callingActivity.ElementID)
                  'copy embedded elements
                  dim embeddedElement as EA.Element
                  for each embeddedElement in element.EmbeddedElements
                        'check if the embedded element is shown on this diagram
                        ' get the diagramObject for the embedded element
                        dim embeddedDiagramObject
                        set embeddedDiagramObject = getDiagramObjectFromArray(embeddedElement.elementID, diagramObjects, count)
                        if not embeddedDiagramObject is nothing then
                              'if yes then make a new embedded elementin the callingActivity
                              dim newEmbeddedElement as EA.Element
                              set newEmbeddedElement = callingActivity.EmbeddedElements.AddNew("","ObjectNode")
                              newEmbeddedElement.Name = embeddedElement.Name
                              newEmbeddedElement.Stereotype = "IntermediateEvent"
                              newEmbeddedElement.Update()
                              newEmbeddedElement.SynchTaggedValues "BPMN2.0","IntermediateEvent"
                              newEmbeddedElement.TaggedValues.Refresh
                              'Copy tagged values
                              copyTaggedValuesValues embeddedElement, newEmbeddedElement
                              ' set the element id of the diagramobject to the new embedded element
                              'embeddedDiagramObject.ElementID = newEmbeddedElement.ElementID
                              'embeddedDiagramObject.Update
                              'for some reason the update doesn't want to work. so we do it the hard way
                              dim updateEmbeddedDiagramObjectSQL
                              updateEmbeddedDiagramObjectSQL = "update t_diagramobjects set object_id = "& newEmbeddedElement.ElementID &" where Diagram_ID = " & diagramObject.DiagramID & " and Object_ID = " & embeddedElement.ElementID
                              'Session.Output updateEmbeddedDiagramObjectSQL
                              Repository.Execute updateEmbeddedDiagramObjectSQL
                        end if
                  next
            end if
      end if
end function
Synchronize function in a second post.
« Reply #2 on: September 02, 2015, 04:54:11 pm »
And here's the synchronizeElement function:
' Synchronises the names of the selected objects or BPMN Activities with their classifier/called activity ref.
' Will also set the composite diagram to that of the classifier/ActivityRef in order to facilitate click-through
function synchronizeElement (element)
      'first check if this is an object or an action
      if not element is Nothing then
            if (element.Type = "Object" OR element.Type = "Action") _
            AND element.ClassifierID > 0 then
                  dim classifier
                  set classifier = Repository.GetElementByID(element.ClassifierID)
                  if not classifier is nothing AND classifier.name <> element.name then
                        element.Name = classifier.Name
                        element.Stereotype = classifier.Stereotype
                        element.Update
                        Repository.AdviseElementChange(element.ElementID)
                  end if
                  'elements of type object should also point to the composite diagram of the classifier
                  if element.Type = "Object" then
                        dim compositeDiagram
                        set compositeDiagram = classifier.CompositeDiagram
                        if not compositeDiagram is nothing then
                              setCompositeDiagram element, compositeDiagram
                        end if
                  end if
            elseif element.Type = "Activity" AND element.Stereotype = "Activity" then
                  'BPMN activities that call another BPMN activity need to get the same name and same composite diagram
                  dim calledActivityTV as EA.TaggedValue
                  set calledActivityTV = element.TaggedValues.GetByName("isACalledActivity")
                  dim referenceActivityTV as EA.TaggedValue
                  set referenceActivityTV = element.TaggedValues.GetByName("calledActivityRef")
                  if not calledActivityTV is nothing and not referenceActivityTV is nothing then
                        'only do something when the Activity is types a CalledActivity
                        'Session.Output "calledActivityTV.Value : " & calledActivityTV.Value
                        'Session.Output "referenceActivityTV.Value :" & referenceActivityTV.Value
                        if calledActivityTV.Value = "true" then
                              dim calledActivity as EA.Element
                              set calledActivity = Repository.GetElementByGuid(referenceActivityTV.Value)
                              if not calledActivity is nothing then
                                    'set name to that of the called activity
                                    element.Name = calledActivity.Name
                                    element.Update
                                    'Set composite diagram to that of the called activity
                                    setCompositeDiagram element, calledActivity.CompositeDiagram
                              end if
                        end if
                  end if
            end if
      end if
end function
« Reply #3 on: September 02, 2015, 08:06:58 pm »
To summarize (without having looked into Geerts code):
- create a new element of type Object
- set the classifier to the class you want to instantiate from
« Reply #4 on: September 03, 2015, 09:11:16 am »
And don't forget...
« Last Edit: September 03, 2015, 09:17:55 am by KP »
