Author Topic: Generate Root Node Model from MDG Technology  (Read 5143 times)
Yannick
« on: September 17, 2015, 07:42:37 pm »
I use Enterprise Architect version 12.0.1215.
I have created my own MDG Technology with a template model usable from Model Wizard window when creating a new project.
I have multiple packages in my template model under a parent package.
My goal is to have this parent package included in my template model as Root Node of the project. All tests I made right now create always a new package under a generic Root Node.
Is it possible to set this parent package in my MDG Technology as Root Node ?
An alternative could be to have multiple packages (without parent package) in a unique XMI file but I don't find how to do it.
Thanks for your help and best regards,
« Last Edit: September 17, 2015, 07:43:25 pm by yannick.butin »
Aaron B
Re: Generate Root Node Model from MDG Technology
« Reply #1 on: September 18, 2015, 10:57:52 am »
No.  New models added via the Model Wizard dialog will always go under the currently selected package (or root node).  It is not possible to have the new model created as a root node itself.
Yannick
« Reply #2 on: September 18, 2015, 04:20:18 pm »
Thanks for your quick reply.
Have you any idea about my alternate solution ?
How can we export multiple packages (without parent package) in a single XMI file ?
This solution could be a workaround to have multiple packages directly attached to the selected package (or root node) where we want to add the MDG template model.
Thanks again and best regards,
