Author Topic: Load Addin only for a certain repository  (Read 3936 times)
E.Eckstein
« on: September 22, 2015, 04:38:26 pm »
Hi dudes and dudines  ;D
I have a requirement and I got no idea how to realize it. The search in .chm and the forum didn't change this issue.
My problem is following: In the company, some users are working on different repositories (Oracle DBs). The Add-In I developed is quite spezialized and though I know it shouldn't it might crash if it is used in the wrong repository (some special guid's missing etc.) ...
So what I want to do is deativate the Add-In if an different repository is opened.
I had something in mind like developing an 2nd Addin, which could listen to project opened or something like this and deativate the actual Add-In.
I am afraid I can't find a method or something similar to deativate an running Add-In.
Some ideas?
Best Regards,
Eric
Aaron B
Re: Load Addin only for a certain repository
« Reply #1 on: September 22, 2015, 05:04:19 pm »
Can't think of any way to prevent the add-in from loading as this happens before you have connected to any repository.  My suggestion would be to have your add-in check the value of Repository.ConnectionString and/or Repository.RepositoryType() and then handle as appropriate.  E.g. check these values in EA_GetMenuState and disable the menus when not connected to your Oracle repository.
E.Eckstein
« Reply #2 on: September 22, 2015, 05:08:17 pm »
Hey Aaron,
thank you very much for you fast reply.
Yes I thought so. I might check the connectionstring as you said, save it to a static variable and just return from events fired by EA if we are in the wrong state.
Well thank you again,
If someone else has an idea - I'll still check the thread in time :)
Eric
« Reply #3 on: September 22, 2015, 08:38:14 pm »
I would do as Aaron suggests.
But technically you can in fact use an add-in to load (or not) other addins.
I'm working on such a project  (soon to be released) but it is no easy task.
