Author Topic: Can automation handle MDG Stereotype items?  (Read 4680 times)
« on: September 22, 2015, 06:18:38 pm »
Elsewhere I've mentioned we're looking at implementing "Aspect Oriented Shapescripts" (TM).  A such, we have a lot of code snippets that need to be incorporated into a large number of shapescripts.
Assuming we could construct a script that assembles the required shapescript for a given stereotype in the MDG, is the automation smart enough to perform the requisite encryptions for the _image and icon attributes of the item?
Have I explained the problem well enough?
TIA,
Re: Can automation handle MDG Stereotype items?
« Reply #1 on: September 22, 2015, 08:03:30 pm »
I did not understand it. But that doesn't mean much  ;)
« Reply #2 on: September 23, 2015, 09:50:51 am »
Yes, it's not obvious what I'm asking.  I was on the bus going home when I crafted the question (and now I'm on the bus going to work) so I wasn't as forthcoming as I should have been.
When I'm constructing an MDG, as I edit the _image attribute of the stereotype item through the UI, EA will store the shapescript as a zipped Base64 encoded value.
My question is: If I set the value of the same _image attribute using automation will it also store the value I supply (the text of the shapescripts) as a zipped Base64 encoded value.  Similarly for the other encoded attributes.
Does that make it clearer?
« Reply #3 on: September 23, 2015, 03:33:08 pm »
Paolo,
I haven't tried it myself, but it seems simple enough to go either way.
If indeed the shapescript is already saved in the database in zipped/base64 encoded format then I'm guessing you'll have to zip/base64 encode the shapescript yourself.
« Reply #4 on: September 23, 2015, 04:30:00 pm »
Paolo,
That's what I was hoping to avoid.  :-/
I didn't want to add all that additional infrastructure.  I might formally ask Sparx.
