Author Topic: Most efficient way to test locked package/element  (Read 5770 times)
Guillaume
    • www.umlchannel.com
« on: September 21, 2015, 04:39:16 pm »
I'm working on an add'in that carries recursive updates on a package or element and its subelements.
Having the Security and/or Version Control configured on the opened project, I need to prevent the recursive job if an element is locked.
I test the Locked property on a selected element so that can be prevented for a selected element, if it is locked.
However is there an easy and efficient way to test if a package/element or one of its subelements is locked, in which case we don't process anything.
I could run a foreach element / package in package until an element is locked, but this doesn't sound like an efficient way to go...
I guess a SQL query might be better? Surely this must be a recurring issue to sort for add'ins.
Guillaume
Re: Most efficient way to test locked package/elem
« Reply #1 on: September 21, 2015, 05:03:18 pm »
Hi Guillaume,
Yes, you could use an SQL query to figure it out.
Since the EA model is a tree I would use a recursive approach
- Suppose you start at PackageA
- Use a query to find all locks for elements in the package. Something like
select o.ea_guid from t_object o
join t_seclocks s on o.ea_guid = s.EntityID
where o.Package_ID = 123
union
select d.ea_guid from t_diagram d
join t_seclocks s on d.ea_guid = s.EntityID
where d.Package_ID = 123
- Do the same for all sub-packages.
That will get you all the locks, but it doesn't mean they are read-only.
We use Require User Lock to edit, and i use this code to figure out if an element is read-only:
       /// <summary>
        /// returns true if this element is readonly
        /// </summary>
        /// <returns>true if this element is readonly</returns>
        public override bool isReadOnly()
            if (this.isLocked())
                string SQLQuery = @"select s.UserID from t_seclocks s
                                    where s.entityID = '" + this.getGUID() + "'";
                XmlDocument result = ((EAModel)this.model).SQLQuery(SQLQuery);
                XmlNode userIDNode = result.SelectSingleNode("//UserID");
                if (userIDNode.InnerText.Equals(((EAModel)this.model).getWrappedModel().GetCurrentLoginUser(true), StringComparison.InvariantCultureIgnoreCase))
                    return false;
            //else
            return true;
IsLocked() looks like this:
       /// <summary>
        /// returns true if currently locked
        /// </summary>
        /// <returns>true if currently locked</returns>
        public override bool isLocked()
            return (this.getLockedUser() != string.Empty);
and getLockedUser() finally does this:
       /// <summary>
        /// returns the name of the user currently locking this element
        /// </summary>
        /// <returns>the name of the user currently locking this element</returns>
        public override string getLockedUser()
            string lockedUser = string.Empty;
            //if (this.wrappedElement.Locked)
                string SQLQuery = @"select u.FirstName, u.Surname from t_seclocks s
                                    inner join t_secuser u on s.userID = u.userID
                XmlNode firstNameNode = result.SelectSingleNode("//FirstName");
                XmlNode lastNameNode = result.SelectSingleNode("//Surname");
                if (firstNameNode != null && lastNameNode != null)
                    lockedUser = firstNameNode.InnerText + " " + lastNameNode.InnerText;
            return lockedUser;
Guillaume
« Reply #2 on: September 21, 2015, 05:20:26 pm »
Thanks Geert!  :)
I'll try it out.
Guillaume
Guillaume
« Reply #3 on: September 23, 2015, 04:43:32 pm »
Hi Geert,
I figured out that I need to address both version control and EA security. I started with the VC considering a package cannot be processed if I get one of the following: csCheckedIn, csReadOnlyVersion, csCheckedOutToAnotherUser, csCheckedOutOfflineByOther
I started testing a Package VC status with the method VersionControlGetStatus(). To make things easier, I'd like to test it against values from the enumeration EnumCheckOutStatus (see Package help page).
I cannot find this enum from EA API. So I attempted to create a similar enum but comparison with the method returned values don't work.
Has anyone successfully used the Check Out Statut enum values?
   public enum EA_EnumCheckOutStatus
        csUncontrolled = 0,
        csCheckedIn = 1,
        csCheckedOutToThisUser = 2,
        csReadOnlyVersion = 3,
        csCheckedOutToAnotherUser = 4,
        csOfflineCheckedIn = 5,
        csCheckedOutOfflineByUser = 6,
        csCheckedOutOfflineByOther = 7,
        csDeleted = 8
Guillaume
