Author Topic: ActiveXObject is not defined  (Read 12719 times)
Erik Holleboom
« on: September 25, 2015, 09:04:50 pm »
I try to instantiate an active X object like Word....
But I seem to get stuck on ActiveXObject is not defined?
I cannot find out what to do to make this possible. I see many examples doing it, but what needs to be enabled(option or simething alike) or present (tool)?
Erik Holleboom
Re: ActiveXObject is not defined
« Reply #1 on: September 25, 2015, 09:10:40 pm »
After changing  from javascript script to jscript it worked.
Apparently there is some security difference
« Reply #2 on: September 25, 2015, 10:35:26 pm »
Its a syntax difference, not a security difference. There another syntax you need to use for JavaScript. Check the examples in the EAScriptLib MDG for examples in all three languages.
JDT
  • It never hurts to help - [Eek the Cat]
« Reply #3 on: February 14, 2020, 01:24:04 am »
Instead of this (JScript):
var xmlDOM = new ActiveXObject("MSXML2.DOMDocument.6.0");
try this (JavaScript) instead:
var xmlDOM = new COMObject("MSXML2.DOMDocument.6.0");
That should work.
