Author Topic: How to find composite diagrams via SQL?  (Read 5457 times)
Svend Erik Nygaard
  • Business Information Architect
« on: October 07, 2015, 02:21:41 am »
I add a composite diagram to an object:
On a diagram: on an object: context menu -> ”New Child Diagram” -> ”Composite Structure Diagram” (or ”Select Composite Diagram).
If done from an activity in a BPMN process diagram, I can find this diagram by:
t_diagramobjects.Object_ID  -->  t_objects.DATA1  -->  t_diagrams
BUT: If done from a class in a class diagram, I can NOT find it.  How do I find the composite diagram in that case?
« Last Edit: October 07, 2015, 02:23:27 am by svenderiknygaard »
Re: How to find composite diagrams via SQL?
« Reply #1 on: October 07, 2015, 03:45:27 am »
Here's what I use to set the composite diagram in VBScript
'set the given diagram as composite diagram for this element
function setCompositeDiagram (element, diagram)
      if not diagram is nothing then
            'Tell EA this element is composite
            dim objectQuery
            objectQuery = "update t_object set NType = 8 where Object_ID = " & element.ElementID
            Repository.Execute objectQuery
            if element.Type = "Object" then
                  'Tell EA which diagram is the composite diagram
                  dim xrefQuery
                  [highlight]xrefquery = "insert into t_xref (XrefID, Name, Type, Visibility, Partition, Client, Supplier) values ('"&CreateGuid&"', 'DefaultDiagram', 'element property', 'Public', '0', '"& element.ElementGUID & "', '"& diagram.DiagramGUID &"')"[/highlight]
                  Repository.Execute xrefquery
            elseif element.Type = "Activity" then
                  'for activities we need to update PDATA1 with the diagramID
                  dim updatequery
                  updatequery = "update t_object set PDATA1 = "& diagram.DiagramID & " where Object_ID = " & element.ElementID
                  Repository.Execute updatequery
            end if
      end if
end function
Svend Erik Nygaard
« Reply #2 on: October 13, 2015, 02:29:34 am »
Great, Geert, I hope to try with xref soon.
I had already noticed the NType=8, but not found the xref rows.
Thanks a lot :-)
