Author Topic: How add a confirmation box in a jscript  (Read 9309 times)
peigee
« on: November 17, 2015, 05:43:37 pm »
Tried window.confirm() in my jscript but EA wouldn't recognise it. Tried Session.prompt("xxx",2) however, it does not seem to return any value regardless Yes or No selected.
How can I add a confirmation box for user to confirm to proceed in Jscript (or should I change to VB)?
Thanks for your help in advance.
Re: How add a confirmation box in a jscript
« Reply #1 on: November 17, 2015, 06:37:34 pm »
peigee,
You need the JScript equivalents of:
      dim oWindowsScriptingHost, iUserResponse
      Set oWindowsScriptingHost = CreateObject("Wscript.Shell")
      iUserResponse = oWindowsScriptingHost.popup("<popup Text", ,"<Title>", 32+promptYESNOCANCEL+512)      ' Y/N Cancel, default=Cancel
You need to use the Windows Scripting Host....
« Reply #2 on: November 17, 2015, 06:59:21 pm »
There's an library function in the EAScriptLib MDG technology that does that for you.
PS. Paolo, in VBScript I find it a lot easier to use msgbox like this:
dim response
response = Msgbox ("Text", vbOKCancel+vbQuestion, "Title")
if response = vbOK then
« Last Edit: November 17, 2015, 06:59:52 pm by Geert.Bellekens »
« Reply #3 on: November 17, 2015, 07:12:05 pm »
Cool!
Continuous refactoring under way!
Thanks Geert,
peigee
« Reply #4 on: November 18, 2015, 01:41:49 pm »
Thank you Geert.
Based on a sample script in EAScriptLib, I have created the following function to produce the confirm box I have wanted:
 * Displays a 'Confirm' dialog and returns the OK/Cancel button value that the user had selected.
 * @param[in] promptText (String) The text prompt that will be displayed on the confirm dialog.
 * @param[in] title (String) The text that will appear in the confirm dialog's title.
 * @return A Response value representing the choice the user pressed between OK or Cancel buttons
function DLG_Confirm( promptText /* : String */, title /* : String */ ) /* : Number */
      // JScript has no intrinsic MsgBox method, therefore we have to steal from VBs
      var vbe = new ActiveXObject("ScriptControl");
      vbe.Language = "VBScript";
      return vbe.eval( "MsgBox(\"" + promptText + "\",vbOKCancel+vbQuestion,\"" + title + "\")");
peigee
« Reply #5 on: November 18, 2015, 02:03:26 pm »
Using following call may be better:
return vbe.eval( "MsgBox(\"" + promptText + "\",[highlight]vbYesNo[/highlight],\"" + title + "\")");
However, please keep in mind the returned value for yes button would be 6 (not sure what is the matching constant variable in Jscript, certainly not promptOK).
