Author Topic: SQLQuery results not shown in ModelSearch Window  (Read 9729 times)
peigee
« on: December 02, 2015, 02:43:09 pm »
My following jscript won't show the Repository.SQLQuery returned results from the subsequent ModelSearch window that it had been opened (no errors reported, the sql does return rows when executed in a SQL client), am I missing anything?
            var objID = theElement.ElementID;
            sql = " select ea_guid as CLASSGUID,'Attribute' as CLASSTYPE, Name from t_attribute where Object_ID="+objID;
            Session.Output( sql );
            var queryResult = Repository.SQLQuery( sql )
            if ( queryResult.length > 0 )
                  var      resultDOM = XMLParseXML( queryResult )
                  if ( resultDOM )
                  Repository.RunModelSearch( "", "", "", resultDOM.xml );
peigee
Re: SQLQuery results not shown in ModelSearch Wind
« Reply #1 on: December 02, 2015, 03:29:06 pm »
The queryResult is captured as bellow:
[code]
<?xml version="1.0"?>
<EADATA version="1.0" exporter="Enterprise Architect">
      <Dataset_0><Data>
            <Row><CLASSGUID>{4A1AB6BB-56EA-480d-B698-BA132EF824CD}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DISPUTE_OUTCOME_TYPE_CODE</Name</Row>
            <Row><CLASSGUID>{139F77F1-32BF-436f-B790-3D8EBEB50FE1}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>IP_SVC_DTL_ID</Name></Row>
            <Row><CLASSGUID>{705B0B34-247A-4ff7-B87F-522B71940CFB}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DISPUTE_TYPE_CODE</Name></Row>
            <Row><CLASSGUID>{E24F1889-4FDC-476c-8906-2EBB31719723}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_ACTIONED</Name></Row>
            <Row><CLASSGUID>{ABB15E1E-9E02-45eb-989E-EBCAF651FF9B}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_HEARING_OFFICER_ASSIGNED</Name></Row>
            <Row><CLASSGUID>{CA3A0157-2EF7-47bc-B098-4F32B36D903C}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>HEARING_OFFICER_FULL_NAME</Name></Row>
            <Row><CLASSGUID>{A3D7014E-A80D-49e9-820A-515AEA7914B2}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>HEARING_OFFICER_ID</Name></Row>
            <Row><CLASSGUID>{7335F82C-3C83-4fff-A7C7-7A15BC7D1D07}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_COOLING_OFF_PERIOD_FROM</Name></Row>
            <Row><CLASSGUID>{080B1667-B09E-4e1b-BF87-83B9C968AD3E}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_COOLING_OFF_PERIOD_TO</Name></Row>
            <Row><CLASSGUID>{5CB1DAF7-ED19-4a6e-9852-8122805E063A}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_GROUNDS_DUE</Name></Row>
            <Row><CLASSGUID>{3CF59272-FD93-4070-960B-6072BFFE4FEF}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_GROUNDS_EXTSN_END</Name></Row>
            <Row><CLASSGUID>{8D1DCC89-E1E5-496b-A36A-E2F8D94EC0F0}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_GROUNDS_FILED</Name></Row>
            <Row><CLASSGUID>{DA096288-B31D-4e8a-9983-A5450FA815F0}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_GROUNDS_SERVED</Name></Row>
            <Row><CLASSGUID>{3FB038AD-9067-43ba-A096-317901C756BC}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_INTNT_TO_DEFEND_DUE</Name></Row>
            <Row><CLASSGUID>{109EFA8E-F535-40ca-8D72-BFF1083D1B92}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_INTNT_TO_DEFEND_EXTSN_END</Name></Row>
            <Row><CLASSGUID>{F87646E4-D779-4bb4-AF24-7271798C1E9A}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_INTNT_TO_DEFEND_FILED</Name></Row>
            <Row><CLASSGUID>{B60ADDF2-588C-450a-8830-95339FCF11DD}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_INTNT_TO_DEFEND_SERVED</Name></Row>
            <Row><CLASSGUID>{B400D06A-5728-4ff6-B64D-0645F3020128}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_NOTICE_OF_INTENT_LODGED</Name></Row>
            <Row><CLASSGUID>{B17171EE-0494-4288-8435-E2853C16201C}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_OPP_WITHDRAWN</Name></Row>
            <Row><CLASSGUID>{43FC30CE-49AF-47e8-A35B-3C71AE33E872}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_REPLY_DUE</Name></Row>
            <Row><CLASSGUID>{A01A8848-6847-4781-9A0C-28B0483EF6A8}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_SUSPENSION_REQ</Name></Row>
            <Row><CLASSGUID>{F3BA2F58-5889-4c0e-9768-28044D6C287D}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_SUSPENSION_START</Name></Row>
            <Row><CLASSGUID>{025F979B-289C-4da4-A0BB-D7CDBE93E41E}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_SUSPENSION_END</Name></Row>
            <Row><CLASSGUID>{FBB17B1E-CF5D-4c0b-8D94-24C542E5ED90}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>GROUNDS_COMMENTS</Name></Row>
            <Row><CLASSGUID>{2CD56093-D8E6-4f34-94B1-1C4E6EB168BA}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>GROUNDS_COMPLETE_IND</Name></Row>
            <Row><CLASSGUID>{74447838-42E9-44ed-96B3-BD698DA3F3C3}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DISPUTE_APPEARANCE_TYPE_CODE</Name></Row>
            <Row><CLASSGUID>{8AFD502A-2288-4a19-8342-78A05E6703F1}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>INTNT_TO_DEFEND_COMMENTS</Name></Row>
            <Row><CLASSGUID>{D7051E64-51F7-4e76-AB95-83CCFA7ACF66}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>INTNT_TO_DEFEND_COMPLETE_IND</Name></Row>
            <Row><CLASSGUID>{0951D204-8A6A-49f0-8FEB-54FA2BDA1852}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>INTNT_TO_DEFEND_IND</Name></Row>
            <Row><CLASSGUID>{030CF203-A24D-495f-A782-BABA0A687F9E}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>PRECEDENT_IND</Name></Row>
            <Row><CLASSGUID>{3FC64E36-18EE-4c9a-8464-8BDEAD90FA9E}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>YEAR_OF_ACT</Name></Row>
            <Row><CLASSGUID>{4333A0E0-2352-430c-806B-A163215C662A}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_CREATED</Name></Row>
            <Row><CLASSGUID>{464946C6-0A30-49d6-89C8-031856FF8ADC}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>CREATED_BY_USER_ID</Name></Row>
            <Row><CLASSGUID>{FAB86AEC-08AB-40f3-907F-DC179D7307F7}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>DATE_UPDATED</Name></Row>
            <Row><CLASSGUID>{6E078F26-61B5-422b-B913-EB1C5A14328C}</CLASSGUID><CLASSTYPE>
« Reply #2 on: December 02, 2015, 03:34:54 pm »
EA ignores anything that is not a "select" command. Yours is a " select" command (with leading white space).
« Last Edit: December 02, 2015, 03:35:54 pm by KP »
peigee
« Reply #3 on: December 02, 2015, 03:36:08 pm »
Adding the truncated remaining part due to size limitation from the last post:
Attribute</CLASSTYPE><Name>UPDATED_BY_USER_ID</Name></Row>
            <Row><CLASSGUID>{9A05F85C-9F08-47d5-84FB-F40AFD458830}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>ETL_NAME</Name></Row>
            <Row><CLASSGUID>{9C3BC4B3-A84A-4353-9F65-CA05C2F96F50}</CLASSGUID><CLASSTYPE>Attribute</CLASSTYPE><Name>ETL_RUN_ID</Name></Row>
      </Data></Dataset_0>
</EADATA>
peigee
« Reply #4 on: December 02, 2015, 03:41:04 pm »
Thank KP for your reply.
The leading space in the sql string is not actually a problem as the queryResult did capture the rows and I have also tried in removing the leading space in the sql string.
peigee
« Reply #5 on: December 03, 2015, 09:55:48 am »
Looks like Repository.RunModelSearch() does not understand the XML formatted SQL result returned from Repository.SQLQuery() (per posted), because if I supply the following string, Repository.RunModelSearch() does show the content:
Repository.RunModelSearch("","","","<ReportViewData><Fields><Field name=\"CLASSGUID\" /><Field name=\"CLASSTYPE\" /><Field name=\"Name\" /></Fields></ReportViewData>") ;
peigee
« Reply #6 on: December 03, 2015, 09:58:51 am »
Therefore, this shall be considered a bug!?
peigee
« Reply #7 on: December 03, 2015, 10:12:42 am »
BTW, I am running EA 12.0.1210 version, Windows 7 Enterprise, Microsoft.NET Framework 4.5.1
« Reply #8 on: December 03, 2015, 10:37:00 am »
I have no idea. If you report it through the official channels, somebody will investigate fully.
http://www.sparxsystems.com/support/bug_report.html
OpenIT Solutions
« Reply #9 on: December 11, 2015, 03:05:53 am »
The XML returned by SQLQuery is in a slightly different format to that expected by RunModelSearch...you need to transform it - in code is the only way i found to do it ...
peigee
« Reply #10 on: December 11, 2015, 09:21:10 am »
It has been confirmed to me that Repository.RunModelSearch method does not work with the XML returned from Repository.SqlQuery method. My point is why it doesn't. Certainly an improvement can be easily made here even if it wasn't in the original intention of the RunModelSearch method.
I understand now that converting the SqlQuery returned XML to the format acceptable to RunModelSearch is the only way. There is an sample script (model search operations) describing the expected XML format. I was also provided sample conversioin code (from SQLQuery output) as follows:
!INC Local Scripts.EAConstants-JScript
!INC EAScriptLib.JScript-XML
// The columns that will apear in the Model Search window
var SEARCH_SPECIFICATION = "<ReportViewData>" +
                                          "<Fields>" +
                                          "<Field name=\"CLASSGUID\" />" +
                                          "<Field name=\"CLASSTYPE\" />" +
                                          "<Field name=\"Name\" />" +
                                          "</Fields>" +
                                          "<Rows/>" +
                                          "</ReportViewData>";
function main()
      var theElement as EA.Element;
      theElement = Repository.GetContextObject();
      var sql = " select ea_guid as CLASSGUID,'Attribute' as CLASSTYPE, Name from t_attribute where Object_ID="+objID;
      var queryResult = Repository.SQLQuery( sql );
      Session.Output( "queryResult.length=" + queryResult.length );
            Session.Output( queryResult );
            var resultDOM = XMLParseXML( queryResult );
            // Create a DOM object to represent the search tree
            var xmlDOM = CreateXMLObject();
            // Load the search template
            if( xmlDOM.loadXML(SEARCH_SPECIFICATION) )
                  var node = xmlDOM.selectSingleNode( "//ReportViewData//Rows" );
                  //loop over xml rows returned from sql query
                  var rows = resultDOM.selectNodes("//EADATA//Dataset_0//Data//Row");
                  for (var i=0; i < rows.length; i++)
                        var row = rows.item(i);
                        //available data from the sql statement:
                        var CLASSGUID = row.selectSingleNode("CLASSGUID").text;
                        var CLASSTYPE = row.selectSingleNode("CLASSTYPE").text;
                        var attName = row.selectSingleNode("Name").text;
                        // Add this element to the XML tree
                        AddRow( xmlDOM, node, CLASSGUID, CLASSTYPE, attName );
            if ( xmlDOM )
                  Repository.RunModelSearch( "", "", "", xmlDOM.xml );
function CreateXMLObject()
      var xmlDOM;
      try
             xmlDOM = new ActiveXObject( "MSXML2.DOMDocument.4.0" );
      catch(e)
             xmlDOM = new ActiveXObject( "MSXML2.DOMDocument.6.0" );
      xmlDOM.validateOnParse = false;
      xmlDOM.async = false;
      return xmlDOM;
function AddRow( xmlDOM, rowsNode, CLASSGUID, CLASSTYPE, attName )
      // Create a Row node
      var row = xmlDOM.createElement( "Row" );
      // Add the Model Search row data to our DOM
      AddField( xmlDOM, row, "CLASSGUID", CLASSGUID );
      AddField( xmlDOM, row, "CLASSTYPE", CLASSTYPE );
      AddField( xmlDOM, row, "Name", attName );
      // Append the newly created row node to the rows node
      rowsNode.appendChild( row );
function AddField( xmlDOM, row, name, value )
      var fieldNode = xmlDOM.createElement( "Field" );
      // Create first attribute for the name
      var nameAttribute = xmlDOM.createAttribute( "name" );
      nameAttribute.value = name;
      fieldNode.attributes.setNamedItem( nameAttribute );
      // Create second attribute for the value
      var valueAttribute = xmlDOM.createAttribute( "value" );
      valueAttribute.value = value;
      fieldNode.attributes.setNamedItem( valueAttribute );
      // Append the fieldNode
      row.appendChild( fieldNode );
main();
