Author Topic: The best way to write use cases?  (Read 55525 times)
Larry Tubbs
  • Architects don't do it without a plan!
Re: The best way to write use cases?
« Reply #15 on: February 15, 2003, 05:49:09 am »
This really is a great discussion. It looks like it was put to bed some time ago, but I have to make one comment. Fintan said:
"I avoid the word 'user' in use case texts and always specify the actor name."
I actually avoid the use of the Actor name in favor of "user" allowing relationships to define which actors can use the use case.
-Lar
Steve_Straley
« Reply #16 on: February 15, 2003, 07:02:25 am »
Larry,
I'm not sure "user" works for all situations.  For example, in the system I just UC'd, there were ALOT of system-to-system interactions.  "Actor" is much more "neutral" between an actual person and a system whereas "user" seems to be more restrictive, especially in my situation.
Cheers,
Steve
Steve Straley
Larry Tubbs
« Reply #17 on: February 15, 2003, 11:32:14 am »
Ah, I see.  You are using the word "Actor" rather than the name of the actor doing the action.  That would be much more generic.  That works.  Thanks,
--Lar
garbelini
« Reply #18 on: May 20, 2003, 12:27:32 pm »
Hi all,
I really think it´s a matter of knowing the environment and adapting the official recomendations to it. There really is no rulle that works for everybody and every project. (except for this one  ;))
The deal is to understand the recomendations and know how and when to use them.
I´m just starting to learn this stuff but it´s already clear to me that you can and should adapt the process to your project and not the other way arround.
In other words: I actualy use the word "USER" for any Human<->System interaction within our use cases but I can definitely imagine more complex projects where this would not work.
Cheers,
Marco Garbelini
Cheers,
Marco Garbelini
darryl_staflund
  • &quot;mmmMMMmmm!!!   UML!&quot;  -- Attributed to Homer
« Reply #19 on: May 20, 2003, 03:25:24 pm »
Hi there,
If I am developing an n-tier web application I like to write one use case that handles that handles all the different scenarios of a business process being implemented.
When I draw it up using Enterprise Architect, however, I like to create an abstract use case icon for the use case as a whole and then create concrete particular use case icons for each round-trip from the client to the server and back again.  I then use realize relations to connect them back to the abstract use case icon.
I get a number of benefits from doing this:
1.  I can come up with rough estimates on how long it will take to implement the use case by multiplying the number of client/server requests with the average historical time needed to implement a client/server request.
2.  I can create interaction diagrams for each client/server request, making sure to focus on the calls taking place for it.
3.  I can partition the concrete uses cases to my workmates.
I like it :-)  And this way of partitioning use cases goes hand-in-hand with presentation technologies like Jakarta Struts in which the atomic work unit is an 'Action'.
Cheers,
Darryl
