Author Topic: Non Functional Requirement / Use Case  (Read 25470 times)
adriang
« on: January 13, 2004, 05:25:37 pm »
I know that it is appropriate to use a "realization" line to link a Requirment element to a Use Case element, but what kind of link should be used when dealing with a Non Functional Requirement and a Use Case?
CJ
Re: Non Functional Requirement / Use Case
« Reply #1 on: January 14, 2004, 09:44:02 am »
G'day,
I link all requirements, irregardless of the type, to elements via realization links.
What kind of requirement are you looking at?
Cheers and best regards.
adriang
« Reply #2 on: January 14, 2004, 10:46:15 am »
A non functional requirement which would be used be observed by many use cases.
CJ
« Reply #3 on: January 14, 2004, 11:55:05 am »
G'day again,
I'd stick with the recommendation on using the realization link.
I guess the only question for your situation is whether it is better to link your use cases to the non-functional requirement, or link other types of elements to the non-functional requirement.
Bruno.Cossi
« Reply #4 on: January 14, 2004, 12:06:07 pm »
Does Non Functional requirement refer to stuff like "All the reports must be available in English, French and German"?
For situations like these, we still use realization relationship.
Bruno
adriang
« Reply #5 on: January 14, 2004, 05:27:17 pm »
The situation I'm dealing with might fit in that category.  It would be a performance requirement which would apply accross many use cases.
For example:
UC1 - Retrieve Student Records
UC2 - Retrieve Class Schedules
Non functional requirment: All data retrieval must take no longer than 5 seconds.
Both use cases would need to comply with this requirement.
Bruno.Cossi
« Reply #6 on: January 14, 2004, 06:12:46 pm »
We have had much the same situation and realize relationship worked just fine.
Bruno
adriang
« Reply #7 on: January 15, 2004, 08:17:31 am »
We'll probably use realize links.  Thx.
