Author Topic: Activity vs. Use Case  (Read 50310 times)
Re: Activity vs. Use Case
« Reply #15 on: January 28, 2004, 02:56:41 am »
Trying to answer your questions bottom up:
Ericson Penker: I started reading about these extensions just a few weeks ago. I still have to fit this with another recent book (www.oogpm.de) that does not mention EP at all (however, I liked it). I read the white paper from Sparx and was happy with that - actually I added the extension and I try to get familiar with it (not too bad so far :-)
Activity vs. Use Case: My original problem came from the different methodologies between the book I mentioned above where stereotyped use cases were used for business processes. EA is using stereotype activities. Here my confusion started. I was asking myself: what is a business process in UML terms?
My (current) conclusion: as there is no general way, I'm free in what I can do. I started reading about EP and that helps a lot. Furthermore I'm still ROSE-biased which I try to shake off since I'm focusing on EA.
