Author Topic: Version 3.50 - Build 588 released  (Read 23433 times)
sparks
« on: December 23, 2002, 06:04:32 am »
Changes in Build 588
- Modifed C# parser to handle @ symbol when used as a indicator of a literal string (ignore escaped characters sequences)
- Fixed problem that could cause exception on closing EA when project browser was undocked
- Check for dirty attribute data before changing current record in Attribute dialog
- Modified generation of 'legacy' style bookmarks for RTF documents.
- Modified the way connectors are joined to Decision nodes - now the four points of the Decision are considered the only legal anchor points
- Modified behaviour of Ctrl+Del key in diagram - now performs delete selected object(s) from diagram instead of deep delete of selected item in tree
- Model Issues, Model Glossary and Model Tasks docked lists now support multiple delete of all currently selected items
- Ctrl+Del in Model Issues, Model Tasks and Glossary lists now acts as shortcut to Delete selected item(s)
- Modified handling of function parameter types declared as pointers eg. "double *" & "double*"
- Added ability to drag a top level view from one Project Root Folder to another Project Root Folder
- Added 'Version' as an updatable option in the 'Update Package Status Dialog' available from the Project Tree context menu on a package
- Fixed problem that occurred with display of attributes when View/Options/Diagram/'Zoom to Best Scale' options was unchecked.
- Added check for modified element notes on exit and perform save if required
- Added File/Save Menu option to be consistent with Windows UI guidelines. Function saves current diagram
- Added Element Issues and Element To Do list to the docked Maintenance bar for a single element
- Modified RTF document generator to include check boxes for new element issues and element to do lists
- Modified key stroke handler to exclude some keystrokes from those that cause a record to become 'dirty' (eg. Alt-S)
« Last Edit: January 04, 2003, 02:56:47 am by sparks »
