Author Topic: Business Process Documentation with ARIS EPC  (Read 13618 times)
« on: March 31, 2004, 06:53:37 am »
Hi there,
I wonder whether anybody has experience in documenting business processes analogous to ARIS EPCs? I like this method for its simplicity and try to adopt it for UML. Before asking detailed questions I just wanted to see if there is any response at all. If not - just ignore this topic  ;)
Cheers, Thomas
rvrivera
Re: Business Process Documentation with ARIS EPC
« Reply #1 on: April 14, 2004, 06:25:44 pm »
Hi!
I have a little experience documenting business process with ARIS EPCs.  Now I'm proposing at my work place to do business modeling with uml, particulary with Eriksson-Penker Business Modeling Extensions, for the planning phase of the integration of a lot of small documentation efforts.
Maybe I would can to help you.
« Reply #2 on: April 20, 2004, 01:50:54 pm »
Not much response so far but thanks for responding anyway. My first question is simple: Do you make use of any methodology when moving from EPC to UML? I know by heart that you can go from one model to the other by respecting a few constraints. However, an UML (use-case driven) approach is quite different to what you would do when working with EPC?
Cheers, Thomas
Tom_Andries
  • Unlearn you must.
« Reply #3 on: April 23, 2004, 09:20:05 am »
Thomas,
In EPC's, sequence is rather essential. An event trigers a process, the outcome of which is an event thtat triggers another process ...  Use cases miss this typical  chaining. This apparent lack of structure amongst them is exactly what enables us to change from one organization type to another.
A way of viewing things is one where business processes (expressed as EPC) are supported by automated functions (expressed by UC).
Cheers, Thomas
Tom Andries
     Associate
Method Innovation
« Reply #4 on: April 23, 2004, 01:06:15 pm »
(Two Star Wars fans - wow :))
Meanwhile I started reading books about Use Case Modelling and I found out that Use Case Modelling is much more about synthesis than analysis. This changes the focus dramatically. Ever since I used to talk about Use Case "Analysis". In fact - there is no analysis. So my question was simply a bit silly  :-[
Just forget this topic
