Author Topic: drag and drop auto instance not working  (Read 10194 times)
jrmcdona
« on: September 18, 2004, 04:28:00 pm »
I am trying to drag and drop an object from the Business Process model onto a Robustness diagram. However, I cannot get it to create a new instance. In the tools-options-diagram-behaviors, I have the auto instance unchecked. I have tried both checking and not checking this and also have tried holding down the Ctrl key, but nothing is working. I dont get the auto instance alert message either?
Anybody ran into this before?
Thanks for your help!
mbc
  • Embedded software developer
Re: drag and drop auto instance not working
« Reply #1 on: September 20, 2004, 01:49:38 am »
If you wrote correctly that you are trying to create an instance of an *object*, then that is the problem. You can't instance objects, only classes. Objects are already instances.
Mikkel
jrmcdona
« Reply #2 on: September 20, 2004, 09:50:23 am »
Thanks for your help. I thought that you could drag and drop the object on to the diagram and create a NEW instance of it, in this case my new instance would be saved as an entity.  Though apparently I am going about it the wrong way!
thanks!
sargasso
« Reply #3 on: September 20, 2004, 04:15:13 pm »
If you are trying to copy an object on the same diagram then ctl-C, shift-ctl-V is about the quickest - It even asks nicely for the new instance name, which you can leave blank if desired.
Otherwise just ctl-dragging the class from the tree to the diagram creates a new instance (or I thought it did?)
hth
Bruce
