Author Topic: Eriksson-Penker profiles functionality  (Read 8660 times)
fcomtz
  • Dino
« on: December 15, 2004, 11:58:16 am »
Hi
I'm using the Eriksson Penker business extensions from the UML profiles.
When I try to link an object <<resource>> with a <<process>>  using the <<resource flow>> it responds with the message of "The requested connection is not UML compliant".
Can anyone help me to fix?
Re: Eriksson-Penker profiles functionality
« Reply #1 on: December 16, 2004, 12:33:08 am »
The resource flow works between objects. For your needs the dependency with an appropriate stereotype (e.g. <<use>> or <<supply>>) should work. You could also use the process control from the activity pointing to the ressource.
My understanding of business modelling with UML so far is that you are rather free in how you use the model elements.
