Author Topic: UP example  (Read 11820 times)
Martin Terreni
  • Sorry, I can't write
UP example
« on: December 09, 2004, 06:40:57 am »
does any budy has a good UP example or tutorial for EA (or some casetool similar to EA)?
I'm planning on mapping UP to EA in a standard way for my organisation.
I'm the main process/design consultant here and the others are mainly developers/programers so I would really have to give them the processes step-by-step.
I will be happy to hear any ides about it.
Recursion definition:
mchiuminatto
Re: UP example
« Reply #1 on: December 10, 2004, 10:31:30 am »
You should try this:
Building Web Applications with UML Second Edition
By Jim Conallen
Regards.
Marcello
Martin Terreni
Re: UP example
« Reply #2 on: December 18, 2004, 10:29:31 pm »
thanks
Kevin Brennan
Re: UP example
« Reply #3 on: December 20, 2004, 07:20:41 am »
Another good option is Craig Larman's Applying UML and Patterns. The book takes you through multiple iterations of analysis.
Sr. Consultant at blue sands Inc. and Vice President, Body of Knowledge at the IIBA. All opinions are my own.
mark_neilson
Re: UP example
« Reply #4 on: January 26, 2005, 04:51:30 pm »
Try the ICONIX UP www.iconixsw.com
Doug's books offer a worked example as the basis for a book
Tom_Andries
  • Unlearn you must.
Re: UP example
« Reply #5 on: January 30, 2005, 09:05:22 am »
A) On using/implementing UP:
- "Software Development for small teams - A RUP centric approach" ISBN 0-321-19950-2
- "Adopting the Rational Unified Process - Success with the RUP" ISBN 0-321-20294-5
Both books are small enough yet contain sufficient real life experience to be worth reading.
B1) Usage of EA as modeling tool:
Well, it would actually call to rewrite the tool mentor part, since you just replace Rose or XDE by EA.
However, given the added features of EA, depending your usage of EA, impact may go also to project management, requirements and change disciplines.
B2) Usage of EA to define processes:
I am actually adapting RUP for a governement agency using EA, based on the SPEM profile. This allows me to adapt RUP by a layer created in EA on top of it.
The greatest constraint so far is the restricted HTML generation from within EA.
I have requested a quote for specific HTML generation. (mainly, diagram updates should insert in existing pages and update hyperlinks from the model elements automatically)
Without adapted generation, all links have to be updated manually, which is just not sustainable!
I'll gladly share my work with you, it could be of mutual interest and a strong defender for EA - if the HTML story gets solved-
Tom Andries
     Associate
Method Innovation
