Author Topic: Documenting reports in the Requirements Spec  (Read 8610 times)
jonespm
« on: February 06, 2005, 07:32:39 pm »
Where, in a Requirements Specification, is the 'normal' place to document reports: as a Use Case, as a Supplimentary Specification or maybe elsewhere?
Once we have a spot how would reports normally be specified, prototype documents, a list of data names and some generic style guidelines or ?.
Cheers, Peter
sargasso
Re: Documenting reports in the Requirements Spec
« Reply #1 on: February 06, 2005, 09:42:35 pm »
Well,
They are functional requirements so according to UP they are NOT supplementary requirements.
If they are ad-hoc reports, then they "must" be part of some business process which may give you a clue as to which use case they support.
If they are periodic, then usually one can find a business process to hang them onto and therfore the applicable use case.
But, finally there is always that set of reports that no-one seems to know the reason for their existence - but are also categorised mandatory, high priority, fixed requirements.  Stick them in the "Waste development time and money" use case . ;D
IOW - if you are using use cases correctly there will always be a use case for which the report is a required system artifact.
How to specify them..... hmm - depends on what you're trying to document and who for.
I suppose in UML terms they are boundary classes (i.e. a UI).
In EA I tend to use stereotyped "screen" element.
hth
bruce
