Author Topic: Hardware deployment  (Read 8838 times)
mikewhit
  • Accessing ....
Hardware deployment
« on: February 18, 2005, 03:50:51 am »
The Deployment diagram specifically states that Nodes are 'processing elements'.
However, for documentation purposes, I would like to explicitly include some of the other hardware environment in a diagram (IO capability, attached peripherals), as diagram elements, rather than just as fields within the node. As embedded nodes, probably.
Any other/better suggestions ?
« Last Edit: February 18, 2005, 03:57:23 am by mikewhit »
TrtnJohn
Re: Hardware deployment
« Reply #1 on: February 23, 2005, 01:30:04 pm »
I agree, deployment models are really just containers.  They don't show the associative relationships you are looking form.  What I think you might be describing is a Domain Model.  A Domain Model is a class diagram that contains all of the sub-systems and actors of your system.  Each association is named and describes how they relate.  For example:
User  ---- Types on ---> Keyboard
Just as in any association, the model can also show multiplicity.
mikewhit
  • Accessing ....
Re: Hardware deployment - e.g.
« Reply #2 on: February 24, 2005, 06:37:40 am »
I have found a couple of approximate examples in Realtime UML (Douglass) fig 2.17 and fig 8.18, and associated text.
TrtnJohn
« Reply #3 on: February 24, 2005, 12:50:32 pm »
Craig Larman has posted his whole chapter on Domain Models from his book Applying UML and Patterns on his site.  This may also apply to your problem:
http://www.craiglarman.com/book_applying_2nd/10-domain%20model.pdf
