Author Topic: Abstract Classes and Interfaces  (Read 16568 times)
planetmarshalluk
« on: January 16, 2005, 06:38:43 am »
What exactly is the difference between an abstract class and an interface?
An example would be great ( the canonical Shape->Circle example is at about my level... )
Cheers,
Andrew.
Re: Abstract Classes and Interfaces
« Reply #1 on: January 16, 2005, 01:28:08 pm »
sargasso
« Reply #2 on: January 16, 2005, 02:28:04 pm »
An abstract class cannot be intantiated - but can implement methods and properties.  An interface is a template - it cannot implement anything.
So interface iAnimal might prescribe 3 methods Move, Eat, Sound - any specific animal class must implement their own versions of Move, Eat , Sound for example for a duck:
void Move(origin, dest) {
case medium="land" {waddle(origin, dest)}
case medium="water" {paddle(origin, dest)}
case medium="air" {flap(origin, destination)}
for a cow
void Move(origin,dest) {
walk(origin,dest)
IOW interface methods are implemented by the interface implementor.
Abstract classes on the other hand can implement stuff.
Simplest example I can think of is the observer pattern.  The abstract  "Subject" class implements register(), deregister() and notfy().  Your concrete classes simply inherit these behaviors.  However, you cannot instatiate a Subject viz "mysub=new Subject();".  By extension, abstracts do not have creators etc,
hth
bruce
Rob_M
« Reply #3 on: January 24, 2005, 02:55:00 pm »
If you're a C++ guy, you can think of an interface as a class definition whose methods are ALL pure and virtual.
An abstract class is a class that contains at least one pure virtual function.
Tom_Andries
  • Unlearn you must.
« Reply #4 on: January 30, 2005, 09:18:38 am »
Wasn't there also something about a class having attributes, while an interface has none?
Although, seen from the outside that would make the difference nil, given encapsulation -:)
Tom Andries
     Associate
Method Innovation
Jamie Cash
« Reply #5 on: March 07, 2005, 06:27:59 am »
An interface can have static members though. The only real difference is that an interface cannot contain implementation just a set of methods that should be implemented, although an interface can contain 0 methods and can be used as a container for constant data.
