Author Topic: Tags Generalization  (Read 13645 times)
aghy
Tags Generalization
« on: April 27, 2005, 12:25:25 am »
I'd like to design a UML model, with a Use Case Diagram. I have two Actors, for example Parent and Child: Parent is the parent of Child (Child generalize it).
Parent has a tag named "rights" valued "read".
Of course, Child inherits it, and if I set a new value to rights, it'll overwrite the Parent's value. (For example with "write".)
But what I want is the following: I'd like to preserve the Parent's value and ADD to it the Child's new value, for example: "read"+"write". I'd like to use them together.
Could you help me with some idea, how can I do that?
Thanks a lot,
Agnes ???
slavko
Re: Tags Generalization
« Reply #1 on: April 27, 2005, 12:30:24 am »
Why not have the tag(s) be Read and Write and the value is set to Y or N for both?
-Slavko
aghy
« Reply #2 on: April 27, 2005, 01:44:54 am »
Because it's a more difficult: our system is more complicated, and we don't want to use separated tags for every value.
« Reply #3 on: April 27, 2005, 02:29:29 am »
Try "Allow duplicate Tags" from the options. In that way you see both tags (parent AND child). Actually it does not join both, but you see both.
aghy
« Reply #4 on: April 27, 2005, 05:22:10 am »
Where can I find this? ("Allow duplicate Tags")
Agnes
« Reply #5 on: April 27, 2005, 06:15:51 am »
Tools / Options / Objects / lower right checkmark
Somehow hard to find (like most options)
aghy
« Reply #6 on: April 27, 2005, 07:01:12 am »
Thanks!!! This is what I need!
Agnes  :D
