Author Topic: Complete example: from Business case to code?  (Read 6099 times)
Carlos
  • Mira al cielo y verĂ¡s hasta donde puedes llegar!!!
« on: April 28, 2005, 09:36:58 am »
Hi everybody:
I don't understand very well the integration with the differently diagrams,
I'm wrong or the route must be:
Business case--
                         -->Use Case--
                                              -->... another diagrams?
(exploit with diagrams?)
Do you have some example like:
business case --> use case --> Diagram Activity--> .... ---> classes diagram --> deploy diagram---> components diagram--> etc.. and finally "example.java"? ...
Only a very shot example like "A person like write a text with some dialog box and click in [GO], and show a text: "Hello Carlos: you write: "aaaaaaa" "
Thanks everybody
Dar el ejemplo no es la principal manera de influir sobre los demas; es la Unica.  Albert Einstein.
Re: Complete example: from Business case to code?
« Reply #1 on: April 28, 2005, 12:35:32 pm »
I'd suggest you study the ICONIX approach. The offer a comprehensive way from Use Case to code. There should be a link to a tutorial CD somewhere on Sparx site. (Be warned: it takes weeks until you have it, except you live in Australia)
