Author Topic: Stylesheet to post process XMI content  (Read 5286 times)
Viseu_Prodigy
« on: March 16, 2005, 05:39:37 am »
Hello, again...
Is there any sample of a stylesheet to use for post processing the XMI content? When i export some package to a XMI file i want to convert that content to HTML format. When i use my stylesheet, it don´t give me any error but the output is blank (0 bytes), so i think i´m doing something wrong.. a sample like a identity stylesheet would be very important! Can someone post something simple that works?
Tks
qdlaty23
Re: Stylesheet to post process XMI content
« Reply #1 on: March 29, 2005, 09:55:11 am »
Hi!
I'm using an XSLT Transformation to generate a special xml file containing state model with lots of information on states, decisions and transitions including tagged values.
I use XMI 1.2 export and than XSLT 1.0 transformation. If you wish, I may send you a part of this transformation. I cannot give you the whole because it's being used by my company for MDA process, however as an author of this stylesheet, I can give you part of it as well as some advice if you wish.
Greetz ;-)
Viseu_Prodigy
« Reply #2 on: March 30, 2005, 07:21:15 am »
Tks  :)
I forgot to tell that this problem was solved.  The stylesheet used was converting the XMI format to HTML format and this don´t work... the solution was to add the tag <xsl:output method="xml"/>
Regards
