Author Topic: Problem with Importing Classes  (Read 7650 times)
tomjscott
« on: July 20, 2005, 05:58:22 pm »
I am trying out the 30 day trial version of Enterprise Architect and I'm having a problem with importing an existing source directory for C++.  My source code is a Windows DLL and all classes contain the standard dllexport.
For example, in the main DLL file, the following is declared:
#define OMEGACORE_API __declspec( dllexport )
Then in all the classes that I want to be visible to external users of my DLL, the class is declared as follows:
class OMEGACORE_API MyClass
The problem is that when the classes are imported, EA thinks every class has the name OMEGACORE_API (i.e. instead of MyClass in my above example).
Is there a way around this issue?
colingr
  • that's not a bug, it's a feature...
Re: Problem with Importing Classes
« Reply #1 on: July 20, 2005, 06:55:16 pm »
I think you can get around this by selecting "language macros" from the configuration menu, then adding your
OMEGACORE_API macro. That should work
tomjscott
« Reply #2 on: July 20, 2005, 08:02:58 pm »
Thanks.  That worked great.
