Author Topic: User Manual Vs Use Case  (Read 10729 times)
sc_kew
« on: October 23, 2005, 07:02:08 pm »
Hey, can everyone tell me what's the difference between User Manual and Use Case? I found out both of documentation are telling users what to do on the system.
Thanks!
jeshaw2
Re: User Manual Vs Use Case
« Reply #1 on: October 23, 2005, 07:23:01 pm »
Use Cases have a wider audience than User Manuals.  The actors in some Use Cases are other automated systems.
« Reply #2 on: October 23, 2005, 07:39:09 pm »
Thanks!
Use Cases (when stored in a model like EA) and when created with a formalism are more amenable to automated processing than User Manuals...
I have difficulty reading some user manuals, I can't expect my automatic emitter to be better at it... ;D
« Last Edit: October 23, 2005, 07:39:22 pm by PaoloFCantoni »
« Reply #3 on: October 24, 2005, 02:18:25 am »
I think that User Manual guide users in working with the system. Use Cases tell the system what the user expects it to do.
sargasso
« Reply #4 on: October 24, 2005, 04:14:12 pm »
User manuals tend to be a good source of use cases.  Unfortunately, IMO usually only up to about 60% of the use cases.  I have never seen a user manual (or set of) that cover all the users let alone all the actors.
bruce
Kevin Brennan
« Reply #5 on: October 26, 2005, 12:32:38 pm »
Thomas is right. Use cases are a requirements specification technique that describe what a user needs the system to do, where user manuals are a training technique that teaches a actual user how to get the system to do something. A use case should generally avoid discussing specific UI elements, whereas a user manual is pretty much worthless if it doesn't specifically discuss the UI.
Sr. Consultant at blue sands Inc. and Vice President, Body of Knowledge at the IIBA. All opinions are my own.
