Author Topic: Problems with code gen?  (Read 6505 times)
julian
« on: November 29, 2005, 12:54:03 pm »
Hi all I'm having difficulty with the code gen. The last version I used, 4.5 was fine. However I'm struggling to figure out what magic incantations I have to utter to get it to appear in 6?
Even if I do an MDA transform to java, selecting the nodes on the diagram reveal no code.
Strangely, I have another EAP file which magically generates code all by itself. This was a file I createdin 4.5.
any enlightenment most apprecaited. I'm looking forward to figuring out how to use this stuff!
J
Re: Problems with code gen?
« Reply #1 on: November 29, 2005, 12:59:44 pm »
Hi julian,
What process are you trying to generate the code?
If you right click on a class and select 'Generate Code' what happens?
EA 6 has an option on a package to allow automatic code generation, so this is probably what is happening in your other model.  To edit this option, select a package in the tree and open Project | Build and Run | Package Build Scripts.  The option in question is 'Use Live Code Generation'.
julian
« Reply #2 on: November 30, 2005, 01:30:10 am »
Simon that solved it thanks!
I have no idea how this got turned on in my 4.5-generated version.
A suggestion -- could it be worth having this on by default?
« Reply #3 on: December 01, 2005, 01:03:36 pm »
Probably not.  People use EA for all sorts of things besides code engineering, and this would get in the way for other applications.
