Author Topic: Version 3.51 - Build 601 released  (Read 24906 times)
sparks
« on: February 11, 2003, 02:11:09 am »
Build 601 released on 11-Feb-2003.
Changes and fixes in Build 601
Fixed bug with project workspace button on workspace views toolbar
Fixed error that prevented cancelling a database compact
Added delete constraint and delete requirements from docked properties window using "Delete" key
Modified RTF to better format Attribute constraints
Attribute constraints now use drop list defined in Reference/Types/Constraint Types
Add check box on diagram dialog to hide element stereotype names in current diagram
Fixed bug that caused model upgraded directly from 3.10 to 3.51 being marked as too recent for version 3.51
Fixed problem with label editing that caused difficulty on Right mouse click
Scenario Type dialog - details edit box now wraps multiline text
Fixed bug in Print Preview that renamed EA caption window to -EA (missing current project name)
Fixed bug with changing user login name - EA previously ignored changes
Fixed problem that could occur when security menu item accessed - but no model open
SQL Server now prompts for password when opening model if no password in connect string and login fails
Matrix profiles now accept names > 12 characters
