Author Topic: Constraints question  (Read 7556 times)
« on: February 13, 2006, 02:04:57 pm »
If I have two constraints and want to attach them to an association: how can I distinguish between
a) AND
b) OR
c) XOR
Any hint appreciated.
Re: Constraints question
« Reply #1 on: February 13, 2006, 02:14:36 pm »
I don't quite know what you mean Thomas. Are you speaking of something along the lines of an XOR constraint between two connectors?
I remember doing this with EA back a year and change. The way to do it was not quite what I expected - not that it didn't make sense, but I tried all kinds of subtle (as in "dumb, but unwise nontheless") things first. In the end the results were quite satisfactory, all things considered.
Of course, now I cannot remember how I did it.
Hint: EA models these as a note. There's something like a "constraint note" in one of the dialogs; once you see that you are home free.
While the result is not exactly the {XOR} notation you see in some OMG stuff, it still works out well. You can size the resulting note graphic to make it smaller.
jeshaw2
« Reply #2 on: February 13, 2006, 06:26:01 pm »
a) AND
b) OR
c) XOR
If you are talking about one association with two constraints, I would think you would use Object Constraint Language OCL in the constraints box in the association's properties.
« Reply #3 on: February 13, 2006, 11:27:22 pm »
Thanks for that guys. I'll have to read about OCL then.
