Author Topic: Errors Reverse Engineering C++ code  (Read 7297 times)
sbarnesx
« on: February 21, 2006, 05:23:38 am »
I am reverse engineering some C++ code. It is older C/C++ code that needs to be documented. I am getting the following error for several classes: Unexpected Symbol. Here is an example of code that throws that error:
class MYPROG_DECL StateIndexKey : public CacheIndexKey
This pattern always causes EA to throw the error.
Any help would be very helpful.
Re: Errors Reverse Engineering C++ code
« Reply #1 on: February 21, 2006, 01:08:52 pm »
Look at http://www.sparxsystems.com.au/EAUserGuide/index.html?languagemacros.htm and define MYPROG_DECL as a macro under Settings | Preprocessor macros.
sbarnesx
« Reply #2 on: February 22, 2006, 01:57:58 pm »
Thank you for the help. I actually ended up adding 3 missing macros. Once I did that, everything imported perfectly!
