Author Topic: List of unrealized Requirements vs Use Cases?  (Read 10884 times)
alzamabar
« on: March 26, 2006, 05:02:18 am »
Hi, just wanted to know if there was a function out there to list all the unrealized Requirements vs Use Cases? I know that with links I can see what Use cases realize a certian Requirement and viceversa, but is there a function which lists all the requirements not realized by a use case?
Bruno.Cossi
Re: List of unrealized Requirements vs Use Cases?
« Reply #1 on: March 26, 2006, 06:52:38 am »
try menu Project > Documentation > Implementation Details.
Hope this helps!
Bruno
alzamabar
« Reply #2 on: March 26, 2006, 08:04:43 am »
Hope this helps!
Bruno
Thanks, that helped, since I can see the list of all the unimplemented types. However I can't filter per type (for instance, I can't say: I want to see all the unimplemented requirements)
Bruno.Cossi
« Reply #3 on: March 26, 2006, 08:11:48 am »
actually, you can. Try button "Set Target Types" (a little cryptic caption indeed). In the window that opens, you can specify which element types you would like to have included in the report.
Hope this helps!
Bruno
alzamabar
« Reply #4 on: March 26, 2006, 10:14:26 am »
Oh yep, thanks.
