Author Topic: Reg:Usecase description template  (Read 6907 times)
derKaiser
  • My only superstiton is belief in FACTS.
« on: May 04, 2006, 03:51:52 am »
I'm currently workin on requirement management using EA.
I created some use cases for the system.
When i document it using "Use Case description Template" the use cases are documented in alphaetical order.
I want the Usecase description as a flow, that is same flow as the Diagram.
Is it possible to do that EA.??
Peace
DerKaiser
Re: Reg:Usecase description template
« Reply #1 on: May 04, 2006, 11:02:24 am »
Just to clarify that: you use the RTF documentation template?
Try to search this forum for "Use Case Driven" and similar. There are quite some good threads about this topic.
DerPapst ;)
« Last Edit: May 04, 2006, 11:03:01 am by thomaskilian »
derKaiser
« Reply #2 on: May 04, 2006, 08:41:23 pm »
Respected DerPapst,
Ya, I am usin RTF template.
when i  document the use cases alone..the usecases descriptioncomes in alphabetical order.
Thanks for ur suggestion to this "der große Kaiser "  ;)
DerKaiser
derKaiser
« Reply #3 on: May 05, 2006, 01:27:16 am »
I want to add the links of the usecases into the "Usecase description document" ..how to do it?
