Author Topic: Version 3.51 - Build 602  (Read 21113 times)
sparks
« on: February 16, 2003, 09:33:24 pm »
Changes and FIxes in Build 602
Fixed problem with drop menus for code gen and RTF reports in Workspace toolbar not being always enabled
Fixed problem with label on generic input dialog box being empty in some cases
Added support in Delphi for reintroduce keyword
Fixed problem with Association Class connector not being displayed after class edit
Added 'Stop' cutton to spell check dialog to allow cancel of spell check during execution
Fixed loss of open project name in caption bar after print preview
Added View menu option for animated menus - None, Slide, Unfold or Fade
Added XP style 'faded icons' for toolbars and menus
Fixed bug in Search dialog that caused problem when no search type was defined
Task dialog, percent complete 'spinner' direction reversed to Windows standard
New UseCase diagram from context menu was defaulting to Class in dialog - fixed
Using keys to manually resize an element now marks diagram as dirty
AssignedTo: field in Tas Detail dialog now correctly includes drop list of project resources/authors
Fixed problem with Zicom Mentor Add-In registration menu item (in Help) not always being avaiable in Desktop version of EA
Modified drawing code to correct slight increase in vertical gap between operations and attributes introduced in build 589
Modified C++ parser to prefer CPP comments for operations over .H ones if C++ options "Comments in Header" unchecked
