Author Topic: Use case links to diagrams...  (Read 7323 times)
Prostomax
« on: September 12, 2006, 06:54:52 am »
Hi.
I will appreciate any help with the following issue:
I developed a set of use cases and for each of them I try to create linked diagram. So, in other words when you click on the use cases graphics you will jump to the new diagram with details.
I so in example project (EA example) that such use cases have link (or "infinity"?) sign in right bottom corner of ellipse.
However, I cannot find how to do such link.
I tried first to add activity diagram in tree view under the use case itself and then create link but think not works.
Any ideas?
Re: Use case links to diagrams...
« Reply #1 on: September 12, 2006, 07:01:40 am »
Right click on the use case element, then choose Advanced / Composite Element from the context menu. Fro some reason you don't seem to be able to do this from the Element pad of the main EA menu.
Note that I am using EA version 6.5, build 797. I do not remember if this worked in earlier versions of EA.
Prostomax
« Reply #2 on: September 12, 2006, 07:19:18 am »
thanks, this works.  ::)
